跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If the router isn't working and it is established that the antennas are defective this is the guide for you.
  1. Make sure the antennas are in a straight position, not bent, to remove the black casing. Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  5. Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  6. Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
结论
After the repairs are made the device should working.
2等其他人完成本指南。
Derek Myers
于2011年10月04日注册
264 信誉积分
创作了5篇指南
团队
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G21
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 2,149
