跳转到主内容
Lenovo Yoga 6 13ALC6 SSD Replacement
Spencer Day
Spencer Day4 其他贡献者
最后更新于 March 19, 2024
10 - 30 分钟
中等
Use this guide to replace the SSD on your Lenovo Yoga 6 13ALC6.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 SSD Replacement, Insert the opening pick: 步骤 2 中的图像 1,2 Lenovo Yoga 6 13ALC6 SSD Replacement, Insert the opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: 步骤 3 中的图像 1,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: 步骤 3 中的图像 2,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 SSD Replacement: 步骤 5 中的图像 1,3 Lenovo Yoga 6 13ALC6 SSD Replacement: 步骤 5 中的图像 2,3 Lenovo Yoga 6 13ALC6 SSD Replacement: 步骤 5 中的图像 3,3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 SSD Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 6 13ALC6 SSD Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 6 13ALC6 SSD Replacement: 步骤 6 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: 步骤 7 中的图像 1,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: 步骤 7 中的图像 2,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: 步骤 7 中的图像 3,3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the SSD: 步骤 8 中的图像 1,2 Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the SSD: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the 2.5 mm screw securing the SSD.
  9. Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: 步骤 9 中的图像 1,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: 步骤 9 中的图像 2,3 Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: 步骤 9 中的图像 3,3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
  10. Lenovo Yoga 6 13ALC6 SSD Replacement, Reassembly notes: 步骤 10 中的图像 1,1
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
104,591 声望
创作了740篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,845篇指南
1指南评论
Love how everyone says a 2280 won’t fit but the bracket all it does it converts the 2242 to fit in a 2280 slot lol. 2280 works just fine. Stuck an 8TB in mine.
GTAGriff900's Channel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 121
总计 5,136
