跳转到主内容
Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement
Slade Fernandes
Slade Fernandes4 其他贡献者
最后更新于 May 7, 2024
20 - 30 分钟
中等
需要更多图片
Are you having trouble hearing sound from your Lenovo Yoga 3 11 laptop when plugging in your headphones, or with your usb port when it does not recognize usb devices? If yes, then you have come to the right place! Your laptop's audio jack/USB port assembly may need to be replaced. This guide will provide you with the information on how to accomplish this replacement task.
你所需要的
工具
查看更多...
  1. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement, Audio Jack/USB Port Assembly: 步骤 2 中的图像 1,2 Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement, Audio Jack/USB Port Assembly: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect the ZIF connector securing the "IO Side" of the USB ribbon cable. Gently lift up the black tab on the connector and the ribbon cable should come free.
  3. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement: 步骤 3 中的图像 1,3 Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement: 步骤 3 中的图像 2,3 Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement: 步骤 3 中的图像 3,3
    • Remove the two 2 mm Phillips #00 screws securing the audio jack/USB port assembly.
    • Gently lift the audio jack/USB port assembly free of the device.
结论
另外一个人完成了本指南。
Slade Fernandes
于08/27/15注册
532 声望
创作了3篇指南
团队
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G3
4 名成员
创作了11篇指南
一条评论
Where can you purchase the part?
Steve Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 8
总计 3,084
