跳转到主内容
Lenovo Thinkpad T440s Keyboard Replacement
Terelle Montalvo
Terelle Montalvo2 其他贡献者
最后更新于 November 29, 2023
15 - 20 分钟
中等
Are some of your keys not working when you type? Consider using this guide to replace the keyboard of your device.
你所需要的
  1. Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Start with the laptop open and the keyboard exposed.
  2. Lenovo Thinkpad T440s Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo Thinkpad T440s Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo Thinkpad T440s Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use the metal spudger to press the keyboard plate forward towards the display
  3. Lenovo Thinkpad T440s Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdrivers to remove the six screws holding in the keyboard.
  4. Lenovo Thinkpad T440s Keyboard Replacement: 步骤 4 中的图像 1,3 Lenovo Thinkpad T440s Keyboard Replacement: 步骤 4 中的图像 2,3 Lenovo Thinkpad T440s Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use the metal spudger to lift up the keyboard plate.
    • Run the metal spudger around the plate, applying light pressure until the keyboard pops out.
  5. Lenovo Thinkpad T440s Keyboard Replacement: 步骤 5 中的图像 1,3 Lenovo Thinkpad T440s Keyboard Replacement: 步骤 5 中的图像 2,3 Lenovo Thinkpad T440s Keyboard Replacement: 步骤 5 中的图像 3,3
    • The keyboard can now be rested forward to expose the ribbon cable attaching it to the motherboard.
    • The ribbon cable will come out with a light pull in the opposite direction of its connection.
    • The keyboard is now removed and ready to be replaced.
结论
5等其他人完成本指南。
Terelle Montalvo
于10/22/18注册
1,477 声望
创作了8篇指南
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G5
3 名成员
创作了8篇指南
1指南评论
how can i get a video for guideline?
Taiye Phisical - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 41
总计 5,950
