跳转到主内容
Lenovo ThinkPad T580 Keyboard Replacement
Austin Blakely
Austin Blakely4 其他贡献者
最后更新于 November 25, 2024
15分钟
中等
If the keyboard on your ThinkPad T580 stops working, you can use this repair guide to fix it. The keyboard is responsible for relaying the physical input from the user to the motherboard, so if it isn’t functioning properly it can prevent the owner from using the computer completely.
If your keyboard has malfunctioning keys, such as certain keys registering multiple presses when only pressed once, keys not registering presses at all, key chattering, or if your keyboard stops registering keypresses completely, replacing the keyboard should alleviate your problems.
Luckily, the keyboard in the ThinkPad T580 is modular and can be replaced from the front of the device. You don’t even need to open the back cover!
你所需要的
配件
工具
  • Spudger
    Spudger
查看更多...
  1. Lenovo ThinkPad T580 Keyboard Replacement, Unfasten the keyboard: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the three 3.3 mm captive screws securing the keyboard.
  2. Lenovo ThinkPad T580 Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use a Jimmy to pry under the top left corner of the keyboard.
    • You may head a "click" or "pop" as the clips of the keyboard disengage.
    The keyboard should be removed by sliding it towards the screen, without the need of a "Jimmy". This releases the "hooks" shown on step 4, picture 2 and then it can be lifted safely.
    Peter Georgiev - 回复
  3. Lenovo ThinkPad T580 Keyboard Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Continue prying along the top edge of the keyboard, releasing the clips as you go.
    • Once the top edge has been fully released, grab the top edge and hinge the keyboard upwards on the bottom edge.
  4. Lenovo ThinkPad T580 Keyboard Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Pull the keyboard away from you, releasing the tabs along the bottom edge.
    • Be sure not to pull on the keyboard too excessively, as it is still connected to the motherboard via two ribbon cables.
    • Flip the keyboard over to rest face down over the trackpad.
  5. Lenovo ThinkPad T580 Keyboard Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to lift up the two black, hinged locking flaps on the ZIF connectors on the motherboard.
  6. Lenovo ThinkPad T580 Keyboard Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T580 Keyboard Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt nose tweezers to pull the two keyboard ribbon cables out from the ZIF connectors.
  7. Lenovo ThinkPad T580 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove the keyboard.
    Is it just me, or in reality, do you need to push it upward, just like with the T460/T470/T470/T490 because from what I have seen, you just need to do the same thing as the W10DG model.
    Ellyot Laflamme - 回复
结论
另外一个人完成了本指南。
Austin Blakely
于03/11/19注册
21,403 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,815篇指南
5指南评论
Aren't there screws on the bottom of the laptop that ought to be unscrewed as well? That's what the T580 service guide says, I think.
Daniel Glus - 回复
This guide is wrong. You need to remove three screws on the bottom. Then slide the keyboard forward (towards the screen) and lift it up at the front to remove it.
Mart Conflin -
This guide is indeed incorrect. After just pulling the screws out of the back of the keyboard thinking they were "clips" as stated in the article, I can confirm that you DO need to unscrew the three center screws on the back of the laptop prior to removing the keyboard.
Dave - 回复
Hi Dave.
You and the other commenters are 100% right! I have updated the guide accordingly.
Alex Diaz-Kokaisl -
Is it possible to replace the non-backlit keyboard into backlit one?
Ahmad Naufal Firdaus - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 156
总计 5,946
