Lenovo ThinkPad T16 Gen 3 RAM Replacement
简介
转到步骤 1Follow this guide to remove, replace, or upgrade the RAM in your Lenovo ThinkPad T16 Gen 3 laptop.
The RAM is DDR5 SODIMM, and the laptop supports up to 64GB at 5600MT/s.
你所需要的
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
Pry up the base cover until the clips unfasten.
Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
Lift and remove the base cover.
Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
Lift the edge of the battery with the connector to disconnect it.
Remove the battery
Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
Lower the battery into place so the connector goes over its socket.
Grab the pull tab in the middle of the RAM shield and pull straight up to remove it from its clips.
Use your fingers to simultaneously push the two metal tabs on the edges of the RAM module down and outwards to unlatch them—the RAM should pop up at a slight angle.
Remove the RAM module.
