跳转到主内容
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Ammar Dodin
Ammar Dodin4 其他贡献者
最后更新于 March 19, 2024
20分钟
中等
The hard drive can become faulty if you drop the laptop while it’s running, or if it’s placed under an excessive amount of stress. If the laptop doesn’t boot or indicates hard disk read errors, follow this guide to replace it.
The battery for this device is not easily accessible and cannot be easily removed. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you drain the battery completely before you begin this replacement.
你所需要的
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: 步骤 1 中的图像 1,1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
结论
10等其他人完成本指南。
Ammar Dodin
于01/19/17注册
1,057 声望
创作了6篇指南
团队
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G3
4 名成员
创作了6篇指南
3指南评论
Clear and easy - thanks!
Beth Pierce - 回复
Very good and to the point
al_stewart - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 10,108
