跳转到主内容
Learn the parts of a Gaming PC
Nyssa
Nyssa4 其他贡献者
最后更新于 November 4, 2024
没有估计
非常容易
需要更多图片
社区贡献指南
Learn all the parts to your pc. Also if your looking into buying a computer you have to buy all parts because every part has a very important job.
  1. Learn the parts of a Gaming PC, CPU (Central Processor Unit): 步骤 1 中的图像 1,1
    • CPU (Central Processor Unit) The CPU is the “brain” of the computer, the CPU is electronic circuitry within a computer that carries out the instructions of a computer program by performing the basic arithmetic, logical, control and input/output operations specified by the instructions.
    • When your computer's CPU is getting older, is used to do functions for which it wasn't intended, or overheats due to poor power flow, it could fail completely.
  2. Learn the parts of a Gaming PC, Motherboard: 步骤 2 中的图像 1,1
    • A motherboard is one of the most essential parts of a computer system. It holds together many of the crucial components of a computer, including the central processing unit (CPU), memory and connectors for input and output devices.
  3. Learn the parts of a Gaming PC, RAM (Random access memory): 步骤 3 中的图像 1,1
    • RAM is an acronym for random access memory, a type of computer memory that can be accessed randomly, that is any byte of memory can be accessed without touching the preceding bytes. RAM is found in servers, PCs, tablets, smartphones and other devices, such as printers. More RAM means the faster the computer will be.
  4. Learn the parts of a Gaming PC, PSU (Power supply unit): 步骤 4 中的图像 1,1
    • Most personal computers can be plugged into standard electrical outlets. The power supply then pulls the required amount of electricity and converts the AC current to DC current. It also regulates the voltage to eliminate spikes and surges common in most electrical systems.
    • Power supplies are rated in terms of the number of watts they generate. The more powerful the computer, the more watts it can provide to components.
    • (Underneath is the power supply)
  5. Learn the parts of a Gaming PC, Case: 步骤 5 中的图像 1,1
    • A computer case, also known as a computer chassis, tower, system unit, cabinet, or base unit, is the enclosure that contains most of the components of a computer. Your case can be already done or modded.
    • This is what you plug the display into. It controls anything graphics related in games, the OS, and more.
    • Your GPU is also home to the VRAM (Virtual Random Access Memory) which functions similarly to that of RAM, albeit for graphical-related purposes. More VRAM usually means more performance, handy for intense graphical processes such as 3d rendering.
    • This can be an SSD or a mechanical HDD. It is used to store all data, including the OS, games, documents, and apps.
    • An SSD is generally faster than an HDD, as it can process, read, and write data faster. Mostly gamers and casual workers use SSDs for storage.
    • An HDD is a slower method of storage used everywhere in the last 30 or so years. Nowadays, HDDs are used for servers and computers with large storage requirements.
    • This is the part that allows you to connect to Wireless LAN, but doesn't come with all boards.
    • This can also come in the form of a USB dongle.
    • These are the USB and other ports on the front of the case.
    • By default, these ports are the power button, reset button, and other misc USB ports such as USB-C and USB 3.0
结论
Your finished!
17等其他人完成本指南。
Nyssa
于04/20/18注册
472 声望
撰写一个指南
5条评论
You forgot the GPU, WiFi board, HDD, SSD, and more plug in's.
NR26 - 回复
you forgot a lot of things and you should just IFIXIT ;[
Dovber Levertov - 回复
It's an In-progress guide. It will be completed soon.
guardian10 -
My PC is not working properly when I press the power button the all the lights turn on then it get turn off
Hassan Khan - 回复
@hassankhan49455 i'd recommend you create a forum post on that or ask around in other communities.
ArandomHitman -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 92
总计 3,176
