跳转到主内容
LG BP220 Disc Drive Replacement
Bart Quicho
Bart Quicho3 其他贡献者
最后更新于 June 16, 2015
20分钟
简单
This guide will show you how to open up your Blu-ray player and remove the disc drive, whether it is to install a new one or gain access to the disc drive's components like the reader and tray motor.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. LG BP220 Disc Drive Replacement, Disc Drive: 步骤 1 中的图像 1,2 LG BP220 Disc Drive Replacement, Disc Drive: 步骤 1 中的图像 2,2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Disc Drive Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
  3. LG BP220 Disc Drive Replacement: 步骤 3 中的图像 1,3 LG BP220 Disc Drive Replacement: 步骤 3 中的图像 2,3 LG BP220 Disc Drive Replacement: 步骤 3 中的图像 3,3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
  4. LG BP220 Disc Drive Replacement: 步骤 4 中的图像 1,2 LG BP220 Disc Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive and pull out to remove.
结论
5等其他人完成本指南。
Bart Quicho
于01/13/15注册
478 声望
创作了3篇指南
团队
UW Tacoma, Team 1-1, Rose Winter 2015 UW Tacoma, Team 1-1, Rose Winter 2015 的会员
UWT-ROSE-W15S1G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 8,834
