跳转到主内容
Kenmore 110 Series Washing Machine Water Pump Replacement
Robert Trout
Robert Trout5 其他贡献者
最后更新于 April 14, 2020
15 - 30 分钟
中等
动态照片拍摄
Use this guide to replace a faulty water pump on your Kenmore 110 Series Washing Machine.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: 步骤 1 中的图像 1,1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: 步骤 2 中的图像 1,3 Kenmore 110 Series Washing Machine Water Pump Replacement: 步骤 2 中的图像 2,3 Kenmore 110 Series Washing Machine Water Pump Replacement: 步骤 2 中的图像 3,3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
结论
14等其他人完成本指南。
Robert Trout
于09/26/12注册
1,234 声望
创作了5篇指南
团队
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G43
5 名成员
创作了12篇指南
9指南评论
please provide info on how to test the water pump once it's removed...
Oscar Ramos - 回复
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - 回复
My clothes are still really wet.
Tracy Schultz - 回复
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - 回复
I had to use a pump and pump it out of the drum to effect repairs to the pump
Ryan Curtis -
Moo 110 5072011
Hector Rios - 回复
Lint on clothes when come out of washer
Mike Schladweiler - 回复
Drain Pump runs—No water comes out.
Solution:While pump is running I take a rubber hose narrow enough to fit into part of the kitchen tap connector where the water drains from (You all know this but they're making someone who's never actually noticed...there are two chambers in the tap connector. One is to get water from the button while the machine is running. The other is for the drain water).
I wrapped my hand around the rubber hose and hold it tight against the tap connector to make it airtight. I then blow air into the small hose until I can hear it bubble into the washer..Reminder do this while the pump is running. Get your face away from the hose the moment you hear the bubbles. The water comes suddenly and with full force
I bought my Kenmore portable new from Sears for $600 in the year 2000. It owes me nothing and has never had a problem This drain problem started a couple of years ago after I'd had a cat that shed like crazy for a year. He's gone and problem remains intermittently.
Walter-KEMBLE WellBredNfed - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 58
过去 30 天: 234
总计 62,150
