跳转到主内容
加入维修社区 - 创建账户
Interconnect Cable Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Interconnect Cable Removal, Prepare your phone for disassembly: 步骤 1 中的图像 1,2 Interconnect Cable Removal, Prepare your phone for disassembly: 步骤 1 中的图像 2,2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Interconnect Cable Removal, Heat the right edge: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Interconnect Cable Removal, Insert an opening pick: 步骤 3 中的图像 1,3 Interconnect Cable Removal, Insert an opening pick: 步骤 3 中的图像 2,3 Interconnect Cable Removal, Insert an opening pick: 步骤 3 中的图像 3,3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Interconnect Cable Removal, Separate the right adhesive: 步骤 4 中的图像 1,3 Interconnect Cable Removal, Separate the right adhesive: 步骤 4 中的图像 2,3 Interconnect Cable Removal, Separate the right adhesive: 步骤 4 中的图像 3,3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Interconnect Cable Removal, Heat the bottom edge: 步骤 5 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Interconnect Cable Removal, Separate the corner adhesive: 步骤 6 中的图像 1,2 Interconnect Cable Removal, Separate the corner adhesive: 步骤 6 中的图像 2,2
    • Insert a second pick at the bottom right corner.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Interconnect Cable Removal, Separate the bottom adhesive: 步骤 7 中的图像 1,2 Interconnect Cable Removal, Separate the bottom adhesive: 步骤 7 中的图像 2,2
    • Slide the opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Interconnect Cable Removal, Heat the left edge: 步骤 8 中的图像 1,1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Interconnect Cable Removal, Separate the corner adhesive: 步骤 9 中的图像 1,2 Interconnect Cable Removal, Separate the corner adhesive: 步骤 9 中的图像 2,2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Interconnect Cable Removal, Separate the left adhesive: 步骤 10 中的图像 1,2 Interconnect Cable Removal, Separate the left adhesive: 步骤 10 中的图像 2,2
    • Insert a third opening pick at the bottom left corner.
    • Slide your pick toward the top left corner to separate the adhesive.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  11. Interconnect Cable Removal, Heat the top edge: 步骤 11 中的图像 1,1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Interconnect Cable Removal, Separate the corner adhesive: 步骤 12 中的图像 1,2 Interconnect Cable Removal, Separate the corner adhesive: 步骤 12 中的图像 2,2
    • Insert a fourth opening pick at the top left corner.
    • Rotate it around the top left corner to separate the adhesive.
  13. Interconnect Cable Removal, Separate the top adhesive: 步骤 13 中的图像 1,2 Interconnect Cable Removal, Separate the top adhesive: 步骤 13 中的图像 2,2
    • Slide your opening pick to the top right corner to separate the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Interconnect Cable Removal, Separate the flash adhesive: 步骤 14 中的图像 1,3 Interconnect Cable Removal, Separate the flash adhesive: 步骤 14 中的图像 2,3 Interconnect Cable Removal, Separate the flash adhesive: 步骤 14 中的图像 3,3
    • There's a remaining patch of adhesive directly under the flash.
    • Line up the tip of an opening pick with the flash cutout.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • You should see the opening pick through the flash cutout.
    • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
    • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
  15. Interconnect Cable Removal, Remove the back cover: 步骤 15 中的图像 1,3 Interconnect Cable Removal, Remove the back cover: 步骤 15 中的图像 2,3 Interconnect Cable Removal, Remove the back cover: 步骤 15 中的图像 3,3
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Interconnect Cable Removal, Disconnect the wireless charging coil: 步骤 16 中的图像 1,2 Interconnect Cable Removal, Disconnect the wireless charging coil: 步骤 16 中的图像 2,2
    • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  17. Interconnect Cable Removal, Disconnect the NFC antenna: 步骤 17 中的图像 1,2 Interconnect Cable Removal, Disconnect the NFC antenna: 步骤 17 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the NFC antenna press connector.
  18. Interconnect Cable Removal, Remove the wireless charging coil and loudspeaker screws: 步骤 18 中的图像 1,3 Interconnect Cable Removal, Remove the wireless charging coil and loudspeaker screws: 步骤 18 中的图像 2,3 Interconnect Cable Removal, Remove the wireless charging coil and loudspeaker screws: 步骤 18 中的图像 3,3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  19. Interconnect Cable Removal, Remove the wireless charging coil and loudspeaker: 步骤 19 中的图像 1,3 Interconnect Cable Removal, Remove the wireless charging coil and loudspeaker: 步骤 19 中的图像 2,3 Interconnect Cable Removal, Remove the wireless charging coil and loudspeaker: 步骤 19 中的图像 3,3
    • Insert the point of your spudger in the notch at the top left corner of the loudspeaker.
    • Pry up to unclip the loudspeaker from the frame.
  20. Interconnect Cable Removal: 步骤 20 中的图像 1,3 Interconnect Cable Removal: 步骤 20 中的图像 2,3 Interconnect Cable Removal: 步骤 20 中的图像 3,3
    • Use your fingers to lift the loudspeaker away from the frame to fully separate it.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  21. Interconnect Cable Removal, Disconnect the battery: 步骤 21 中的图像 1,2 Interconnect Cable Removal, Disconnect the battery: 步骤 21 中的图像 2,2
    • Use the point of your spudger to pry up and disconnect the battery press connector.
  22. Interconnect Cable Removal, Disconnect the interconnect cables: 步骤 22 中的图像 1,3 Interconnect Cable Removal, Disconnect the interconnect cables: 步骤 22 中的图像 2,3 Interconnect Cable Removal, Disconnect the interconnect cables: 步骤 22 中的图像 3,3
    • Use your spudger to pry up and disconnect the primary and secondary interconnect cable press connectors from the daughterboard.
  23. Interconnect Cable Removal: 步骤 23 中的图像 1,3 Interconnect Cable Removal: 步骤 23 中的图像 2,3 Interconnect Cable Removal: 步骤 23 中的图像 3,3
    • Repeat the previous step for the primary and secondary interconnect cable connectors on the motherboard.
  24. Interconnect Cable Removal, Remove the interconnect cables: 步骤 24 中的图像 1,2 Interconnect Cable Removal, Remove the interconnect cables: 步骤 24 中的图像 2,2
    • Remove the interconnect cables.
结论
Alex Diaz-Kokaisl
于01/16/22注册
217,554 声望
创作了1,051篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,927篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 34
