跳转到主内容
IdeaPad Yoga 13 Charging Port Replacement
Kaitlyn Johnson
Kaitlyn Johnson2 其他贡献者
最后更新于 June 26, 2019
25 - 45 分钟
中等
需要更好的图片
需要更多图片
Simple guide to disassembling the keyboard down to the motherboard. In detail explains how to successfully replace the charging port.
你所需要的
工具
查看更多...
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: 步骤 2 中的图像 1,2 IdeaPad Yoga 13 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: 步骤 3 中的图像 1,1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: 步骤 4 中的图像 1,2 IdeaPad Yoga 13 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: 步骤 6 中的图像 1,3 IdeaPad Yoga 13 Charging Port Replacement: 步骤 6 中的图像 2,3 IdeaPad Yoga 13 Charging Port Replacement: 步骤 6 中的图像 3,3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
结论
2等其他人完成本指南。
团队
IUPUI, Team S1-G2, Harley Spring 2019 IUPUI, Team S1-G2, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G2
3 名成员
创作了2篇指南
1指南评论
do you have the schematic of the board?
Jorge Herrera - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,787
