跳转到主内容
Huntington GA41PS-RDS Acoustic Guitar String Replacement
你所需要的
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,1
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 2 中的图像 1,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 2 中的图像 2,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 2 中的图像 3,3
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 3 中的图像 1,2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 3 中的图像 2,2
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 4 中的图像 1,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 4 中的图像 2,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 4 中的图像 3,3
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 5 中的图像 1,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 5 中的图像 2,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 5 中的图像 3,3
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 6 中的图像 1,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 6 中的图像 2,3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 6 中的图像 3,3
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 7 中的图像 1,2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 步骤 7 中的图像 2,2
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
结论
Ruhail Khan
于01/18/22注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 36
总计 752
