跳转到主内容
Huawei P9 Battery Replacement
你所需要的
  1. Huawei P9 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P9 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P9 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Battery Replacement: 步骤 2 中的图像 1,2 Huawei P9 Battery Replacement: 步骤 2 中的图像 2,2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Battery Replacement, Fingerprint sensor: 步骤 3 中的图像 1,2 Huawei P9 Battery Replacement, Fingerprint sensor: 步骤 3 中的图像 2,2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Battery Replacement, Battery: 步骤 4 中的图像 1,3 Huawei P9 Battery Replacement, Battery: 步骤 4 中的图像 2,3 Huawei P9 Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Unplug the antenna cable.
    • Remove the sticker that sits on top of the screw.
  5. Huawei P9 Battery Replacement: 步骤 5 中的图像 1,3 Huawei P9 Battery Replacement: 步骤 5 中的图像 2,3 Huawei P9 Battery Replacement: 步骤 5 中的图像 3,3
    • Unscrew the two Phillips #00 screws that hold the metal plate in place.
    • The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
  6. Huawei P9 Battery Replacement: 步骤 6 中的图像 1,2 Huawei P9 Battery Replacement: 步骤 6 中的图像 2,2
    • Now you can unplug the battery connector and bend it aside.
    • The EVA-L09 model has an NFC antenna adhered onto the battery.
    • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
    • Mark its place on the battery with a felt pen for reassembly. Carefully peel it off and make sure not to rip or crease the antenna.
    • For reassembly, place the NFC antenna on the battery where it was before so its contacts align with their counterparts.
  7. Huawei P9 Battery Replacement: 步骤 7 中的图像 1,2 Huawei P9 Battery Replacement: 步骤 7 中的图像 2,2
    • Free the ends of the adhesive pull tabs to get a good grip on them.
  8. Huawei P9 Battery Replacement: 步骤 8 中的图像 1,3 Huawei P9 Battery Replacement: 步骤 8 中的图像 2,3 Huawei P9 Battery Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    购买
    • The battery is secured with three pieces of adhesive, a removable pull-tab in the center, and on the SIM tray side. A third piece of adhesive on the button side has no pull-tab.
    • Pull the adhesive tabs in a slow constant movement to free the battery.
    • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
    • There are two cables running directly underneath the battery. Take care not to damage them when prying with a spudger! You can see their position in the last picture.
    • Slowly lift the battery toward the button side and free it from the remaining hidden piece of adhesive.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
结论
90等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
28条评论
Just FYI, My replacement battery from Huawei doesn’t fit. The cable doesn’t reach the connector. Soldering Required!
https://imgur.com/gallery/vTsX8
dallebull - 回复
Bonjour j es effectué cette opération.J es changé le connecteur de chargeur complet suite à un dysfonctionnement. Et la batterie aussi.Et mon soucis reste le même. Le téléphone s allumé mais pas de voyant de charge.merci de me renseigner.
Berhault - 回复
Bonjour,
J’ai le même problème , avez-vous trouvé une solution ?
Amenis -
Bonjour suite à une panne avec mon huawei p9 j es changé le connecteur de chargeur et la batterie et mon problèmereste toujours le même. Il charge toujours pas.merci de me
Berhault - 回复
Dalebull what the !&&* have you done to the batteries in the pictures
Justinas Vaiciunas - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 45
过去 30 天: 157
总计 125,233
