跳转到主内容
Huawei P20 Pro Screen Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch2 其他贡献者
最后更新于 June 19, 2024
1 - 3 小时
困难
特色指南
Use this guide to replace a defective or cracked OLED screen and digitizer in the Huawei P20 Pro.
Note: This guide instructs you to replace only the display while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure—transplanting all your phone's internals. Make sure you have the correct part before starting this guide.
Opening the Huawei P20 Pro will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water protection.
Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise with caution, or take it to a professional if you're not sure how to proceed.
You’ll need adhesive glue to reattach components when reassembling the device.
你所需要的
配件
工具
查看更多...
  1. Huawei P20 Pro Screen Replacement, Rear Glass Replacement: 步骤 1 中的图像 1,1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    Ich hatte keinen iOpener. Daher hab ich das P20 Pro für ein paar Minuten auf eine Wärmflasche gelegt. Die Klebeschicht konnte relativ schnell gelöst werden.
    David T. - 回复
    Bonjour à toute l'équipe, déjà un grand merci pour votre travail, j'adore vraiment l'état d'esprit.
    J'en suis à l'étape 1 et comme ma vitre arrière est cassé, la ventouse n'adhère pas.
    Donc plan B, comme suggéré malheureusement ma cyanolite ne semble pas adhérer sur le verre, j'essaie avec une bonne colle à chaussure car Trés solide et je laisse sécher la nuit en légère pression, j'espère avoir un minimum de prise afin de glisser les médiators mais le verre est bien brisé et j'ai un peu peur que ça parte en morceaux, croisons les doigts 🤞
    Je vous dirais pour la suite 😉
    Salut à l'équipe, vous faites un travail formidable, merci beaucoup
    cyp cabs - 回复
    @cypcabs avec grand plaisir ! Bravo pour l'ingéniosité en tout cas ! J'espère que vous avez pu ouvrir votre Huawei avec succès entretemps.
    Claire Miesch -
  2. Huawei P20 Pro Screen Replacement: 步骤 2 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 2 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 2 中的图像 3,3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
    if the back cover is not broken, i’d suggest NOT to use an opening pick as if the phone was not heated enough, you may crack the glass on the edges. better use the iPlastix, it is thinner and less stressful for the glass.
    Stefano Restuccia - 回复
    It is better to put a peak on the side because the side opens first than the bottom of the phone.
    이정일 - 回复
    I have to agree that is is much easier to start opening from the side. Do read the rest of the guide though, to make sure you won’t hit something when opening it from the side.
    Jacob Cain - 回复
  3. Huawei P20 Pro Screen Replacement: 步骤 3 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 3 中的图像 2,2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Screen Replacement: 步骤 4 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 4 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 4 中的图像 3,3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Screen Replacement: 步骤 5 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 5 中的图像 2,2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Screen Replacement: 步骤 6 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 6 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 6 中的图像 3,3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Screen Replacement: 步骤 7 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 7 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 7 中的图像 3,3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Screen Replacement: 步骤 8 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Screen Replacement: 步骤 9 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    Das mit den Klebstreifen funktioniert nicht. Ich habe die Tube E6000 in die Dichtungen eingeklebt und so das Smartphone wieder zusammengesetzt.
    yellowlonghair ylh - 回复
  10. Huawei P20 Pro Screen Replacement, Motherboard Cover and NFC: 步骤 10 中的图像 1,1
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Huawei P20 Pro Screen Replacement: 步骤 11 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 11 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 11 中的图像 3,3
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Huawei P20 Pro Screen Replacement: 步骤 12 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 12 中的图像 2,2
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Huawei P20 Pro Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the motherboard cover.
    Porque cuando desconectas el nfc no vuelve a funcionar?
    Vanesa Gutierrez - 回复
    a teraz to zopakuj po vychodňarsky
    Lukas Franko - 回复
  14. Huawei P20 Pro Screen Replacement, Battery Disconnect: 步骤 14 中的图像 1,2 Huawei P20 Pro Screen Replacement, Battery Disconnect: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
    Das Flachbandkabel kann einen Zentimeter zu lange sein. Ich musste ihn 2 mal falten, um beim Einbau die Steckerbuchse wieder zu treffen.
  15. Huawei P20 Pro Screen Replacement, Interconnect Cable with Charging Port: 步骤 15 中的图像 1,1
    • Remove the five Phillips #00 screws (3.4 mm length).
  16. Huawei P20 Pro Screen Replacement: 步骤 16 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 16 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 16 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect the antenna cable.
    • Use a pair of tweezers to pull the antenna cable out of its routing.
  17. Huawei P20 Pro Screen Replacement: 步骤 17 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 17 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 17 中的图像 3,3
    • Slide an opening pick under the left side of the daughterboard cover and start to pry it up until you can get a good grip.
    • Remove the daughterboard cover.
  18. Huawei P20 Pro Screen Replacement: 步骤 18 中的图像 1,1
    • Remove the two Phillips #00 screws (3.4 mm length) on both sides of the USB C port.
  19. Huawei P20 Pro Screen Replacement: 步骤 19 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 19 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the upper end of the interconnect and charging port flex cable from the motherboard.
  20. Huawei P20 Pro Screen Replacement: 步骤 20 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 20 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 20 中的图像 3,3
    • Use the flat end of a spudger to pry up and disconnect the bottom end of the interconnect and charging port flex cable from the daughterboard.
    • Use a pair of tweezers to move the antenna cable out of the way.
  21. Huawei P20 Pro Screen Replacement: 步骤 21 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 21 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 21 中的图像 3,3
    • Use a pair of tweezers to pull the charging port out of its recess.
    • Remove the interconnect cable including the charging port.
  22. Huawei P20 Pro Screen Replacement, Battery: 步骤 22 中的图像 1,3 Huawei P20 Pro Screen Replacement, Battery: 步骤 22 中的图像 2,3 Huawei P20 Pro Screen Replacement, Battery: 步骤 22 中的图像 3,3
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the display for at least two minutes.
    • In the following step, only apply the spudger in the areas marked in red, which is where the battery adhesive is located.
    • Avoid the orange area where the display flex cable is running.
  23. Huawei P20 Pro Screen Replacement: 步骤 23 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 23 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 23 中的图像 3,3
    • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
  24. Huawei P20 Pro Screen Replacement: 步骤 24 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 24 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 24 中的图像 3,3
    • Insert the spudger at the top right corner of the battery and start to pry it up.
    • Work your way down to the bottom end of the battery to loosen all the adhesive.
  25. Huawei P20 Pro Screen Replacement: 步骤 25 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 25 中的图像 2,2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
    Bonjour, le "ôter la batterie " m'a fait rigoler, trois fois chauffer le Iopener pour ramollir la colle et malgré tout, la batterie était tellement bien accrochée qu'elle est maintenant déformé, plier et même percée donc bonne à jeter, j'avais pas prévu de la remplacer mais j'y suis contraint 😑
    Merci encore pour ce tutoriel génial 👍
    cyp cabs - 回复
  26. Huawei P20 Pro Screen Replacement, Screen: 步骤 26 中的图像 1,2 Huawei P20 Pro Screen Replacement, Screen: 步骤 26 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable at the bottom left of the motherboard.
  27. Huawei P20 Pro Screen Replacement: 步骤 27 中的图像 1,1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough on all sides. Follow the iOpener instructions to avoid overheating.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Bonjour l'équipe, je ne comprends pas pourquoi, l'Iopener n'est pas plus large, ses dimensions ne correspondent à aucun téléphone moderne et la tenue en température est faible, en plus il ne supporte pas les chauffe à répétition.
    Peut-être pourriez vous suggèrer le décapeur thermique et nous donner des indications sur les températures à atteindre et les températures maximale...
    Simple suggestions😉
    cyp cabs - 回复
  28. Huawei P20 Pro Screen Replacement: 步骤 28 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 28 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 28 中的图像 3,3
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the plastic bezel. Start to cut the adhesive by sliding the opening pick to the top left corner.
    • Make sure you get in the right gap between the display and the plastic bezel. Do not pry between the bezel and the midframe.
    There will be 2 gaps one under the screen glass(the one you should open) the secod notch down is where a fragile plastic frame is. Stay away from it and use the upper notch
    Abdulrahman Alzahrani - 回复
  29. Huawei P20 Pro Screen Replacement: 步骤 29 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 29 中的图像 2,2
    • Insert a second opening pick and slide it to the top right corner of the phone.
    • Leave the picks in their places to prevent the adhesive from resealing.
  30. Huawei P20 Pro Screen Replacement: 步骤 30 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 30 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 30 中的图像 3,3
    • Insert a third opening pick at the top right corner of the phone.
    • Slide the opening pick down to the bottom right corner to cut all the adhesive. Leave it at the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  31. Huawei P20 Pro Screen Replacement: 步骤 31 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 31 中的图像 2,2
    • Insert a fourth opening pick at the bottom right corner.
    • Only slide the tip of the opening pick along the bottom edge of the phone to not damage the home button.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    C encore moi, j'ai fini par pouvoir insérer un médiator après de nombreuses reprises à 25 centimetres de mon décapeur thermique réglé au minimum après 10 minutes de chauffe et en insérant au préalable sur 3 MM un cuter très petit, si ça peut vous servir 😉
    J'ai juste fait la place d'insérer mon 1er médiator et le reste à été tout seul, colle bien ramolli
    cyp cabs - 回复
  32. Huawei P20 Pro Screen Replacement: 步骤 32 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 32 中的图像 2,2
    • Insert a fifth opening pick and slide it along the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and adhered on the opposite side.
  33. Huawei P20 Pro Screen Replacement: 步骤 33 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 33 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to peel the display flex cable free from the frame.
    • Thread the display flex cable through the gap in the frame and remove the display.
    after this part, even after heating the screen it didn’t come apart in one shot, i had my digitizer, led, and protective all apart and still no access to remove the display flex cable, tore a cable connecting to the screen and now my phone is trash. somehow you managed to bypass this part and magically go to the part where you can see the home button? not happy. “Remove Display” you make it seem so easy yet this is the part that destroyed my phone. Please include the step 33b that we need, thanks
    Bruce Chartrand - 回复
  34. Huawei P20 Pro Screen Replacement, Home button including the fingerprint sensor: 步骤 34 中的图像 1,2 Huawei P20 Pro Screen Replacement, Home button including the fingerprint sensor: 步骤 34 中的图像 2,2
    • Use an opening pick to open the black flap of the home button ZIF connector.
  35. Huawei P20 Pro Screen Replacement: 步骤 35 中的图像 1,2 Huawei P20 Pro Screen Replacement: 步骤 35 中的图像 2,2
    • Use a pair of tweezers to gently pull the home button flex cable out of its ZIF connector.
  36. Huawei P20 Pro Screen Replacement: 步骤 36 中的图像 1,1
  37. Huawei P20 Pro Screen Replacement: 步骤 37 中的图像 1,3 Huawei P20 Pro Screen Replacement: 步骤 37 中的图像 2,3 Huawei P20 Pro Screen Replacement: 步骤 37 中的图像 3,3
    • Apply a spudger to the backside of the home button and push it out towards the front until it comes off the screen.
    • Carefully grab the home button and thread its flex cable through the gap in the screen.
    • Remove the home button.
    • Before installing a new display, it's important to remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
    Wie komme ich den Homebutton wieder fest.
    Nach der Reparatur hängt dieser leicht nach vorne raus. Brauche ich einen speziellen Kleber oder geht auch klassischer Sekundenkleber von UHU?
    Sleepy Lex - 回复
结论
The best way to secure the new screen is with adhesive glue. Apply the glue to the plastic frame, then carefully feed the display cable through its gap, align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
44等其他人完成本指南。
于11/23/16注册
228,969 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,418篇指南
12条评论
Most detailed guide I’ve personally seen. And I love the detailed gif like steps, which are positively the best way to explain something. Hands down. Love it. Only the important stuff without the fluff easily accessible for back and forth.
Can’t stress enough how much I want you to keep using this formula.
*Throws happiness at screen* Here you go man
Ion Ion - 回复
I need some help - I have the new LCD but it’s already in its housing. I am confused how to transfer all the existing parts (cameras, boards etc) onto the new frame! CL
Cameron Lawther - 回复
Bonjour,
L’introduction du tuto stipule : “Ouvrir le Huawei P20 Pro endommagera les joints étanches de l'appareil. Si vous ne les remplacez pas, votre téléphone continuera à fonctionner normalement, mais ne sera plus étanche à l'eau. “
Comment remplacer ces joints ? Un produit en particulier ? Est-ce la colle qui fait office de joint étanche ?
Merci pour les infos,
Aurélien C - 回复
ma compagne a cassé son p20 pro.On annoncait 340 € à réparer.Je trouvais ca beaucoup, mais avec la pièce à 220 €, et 1 à 3h de travail, ca s’explique…+ le cout des outils …Il se trouve à 300 € en 2e main ou fin de série….Mais si on est bricoleur, ca peut etre drole. Courage, et merci pour ce tuto !
gilou gilou - 回复
Hello
I have a question.
We done everthing like it is explained. (Thank you for the amazing instruction!)
But now we want to instal the new lcd screen but there is no fixation for the home button (silver thing). And we can remove the old one. Any suggestions?
Illyris Van Der Meer - 回复
Hey, did you ever find a solution for this??
Alex -
The silver bit that looks like it's part of the chassis, does actually pop out. Make sure not to bend it!!
Alex -
Impresionante tutorial. Lo he seguido tal y como se indicaba, y he podido sustituir perfectamente la pantalla y la batería. Un 10. Gracias
Miguel Angel Lafarga - 回复
Hello,
I´ve just replace the battery and the phone doesn´t not turn on. The screen works and the phone is charging ( i can see the percentage in the screen)
any suggestion? Thanks,
iñigo Diaz - 回复
Hey, did you find a solution for this?
My phone is half assembled to test before sealing, and the screen comes on and I can see it charging, including the percentages, however the power button appears to do nothing?
Alex -
Okay, not certain on this however I got it to work.
There appears to be an anti-tamper or open back sensor switch on the main board, located between the screen ribbon cable connection, and the the flash module, right next to the top of the battery. This is a metal clip looking thing, which I pressed down with a blue plastic spudger to make contact with the board, while holding the power button, the phone turned on.
I also had to do this again in order to turn the phone off.
Alex -
Bravo à vous et merci. Sans ce tuto je n'aurai pas osé.
Ça m'aura coûté moins de 100€ et moins de 4h.
J'ai 0,4mm d'épaisseur de plus qu'avant mais tout fonctionne parfaitement 👍
Merci merci
cyp cabs - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 127
过去 30 天: 408
总计 106,050
