跳转到主内容
Huawei P10 Rear Camera Replacement
你所需要的
  1. Huawei P10 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P10 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P10 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Rear Camera Replacement: 步骤 2 中的图像 1,3 Huawei P10 Rear Camera Replacement: 步骤 2 中的图像 2,3 Huawei P10 Rear Camera Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Rear Camera Replacement: 步骤 3 中的图像 1,2 Huawei P10 Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Rear Camera Replacement, Battery disconnect: 步骤 4 中的图像 1,3 Huawei P10 Rear Camera Replacement, Battery disconnect: 步骤 4 中的图像 2,3 Huawei P10 Rear Camera Replacement, Battery disconnect: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,2 Huawei P10 Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the metal shield.
  6. Huawei P10 Rear Camera Replacement: 步骤 6 中的图像 1,3 Huawei P10 Rear Camera Replacement: 步骤 6 中的图像 2,3 Huawei P10 Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Use tweezers to loosen the bottom end of the adhesive strip, that holds down the flex connector of the rear facing camera.
    • Use the flat end of a spudger to disconnect the camera flex cable.
    • Carefully remove the rear camera.
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
16等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
247,614 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,768篇指南
8指南评论
HI, I need to understand why many of us owners of the Huawei P10 has problems with the camera that does not focus or each photo is always blurred and it takes a side kick to fix it temporarily, then I would also know if changing the camera solve the problem. Thank you.
Jean Pierre Valli - 回复
where to get the best rear camera replacement?
Salihin Saealal - 回复
I have replaced the camera in my phone however the replacement does not work. I have seen comments from other people who have had a similar issue such as https://forum.xda-developers.com/p10/hel...
Could this be a firmware related issue? Perhaps the camera firmware in the replacement part is now older than that expected by the firmware in the phone itself?
Does anyone know where to find information about this sort of thing? Whenever I search the Googles I am always taken to generic pages about flashing boot loaders and various versions of Android, not the actual firmware.
Alex Baker - 回复
where I can buy this camera as long as it is original?
pedrosantiagotavares - 回复
What is misssing in detail: how to open the back case from the display. It was very hard and I need another webpage to get additional infromation.
Compi-Sams - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 50
总计 7,210
