跳转到主内容
加入维修社区 - 创建账户
Huawei Mate 10 Screen Replacement
你所需要的
  1. Huawei Mate 10 Screen Replacement, Remove the back cover: 步骤 1 中的图像 1,3 Huawei Mate 10 Screen Replacement, Remove the back cover: 步骤 1 中的图像 2,3 Huawei Mate 10 Screen Replacement, Remove the back cover: 步骤 1 中的图像 3,3
    • Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone.
    • While you wait, note the location of the adhesive holding the back cover in place.
    询问修复机器人
  2. Huawei Mate 10 Screen Replacement: 步骤 2 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 2 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 2 中的图像 3,3
    • Place a suction cup near the bottom edge of the back cover, on the right side (opposite the speaker grille) of the USB-C charging port, above the microphone hole.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. If all else fails, you can superglue the suction cup to the back cover.
    • Pull on the suction cup with strong, steady force to create a gap.
    • Due to the adhesive's strength, this is very difficult and may take multiple attempts. If you can't create a gap, re-apply heat and try again.
    • Insert the point of an opening pick into the gap.
    询问修复机器人
  3. Huawei Mate 10 Screen Replacement: 步骤 3 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 3 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 3 中的图像 3,3
    • Slide the pick along the bottom edge and around the bottom-left corner, slicing through the adhesive.
    • If the adhesive feels tacky and difficult to slice, re-apply heat to the edge and try again.
    • Leave an opening pick in the seam to prevent the edge from re-sealing.
    询问修复机器人
  4. Huawei Mate 10 Screen Replacement: 步骤 4 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 4 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 4 中的图像 3,3
    • Apply a heated iOpener to the left edge of the phone.
    • Use an opening pick to slice through the adhesive on the left edge of the phone.
    • The adhesive is very thick in some areas. Sustained exposure to heat will help weaken the stubborn adhesive. Take your time, and apply heat liberally.
    询问修复机器人
  5. Huawei Mate 10 Screen Replacement: 步骤 5 中的图像 1,2 Huawei Mate 10 Screen Replacement: 步骤 5 中的图像 2,2
    • Continue heating and slicing through the remaining edges, leaving opening picks in the seams to prevent the adhesive from re-sealing.
    询问修复机器人
  6. Huawei Mate 10 Screen Replacement: 步骤 6 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 6 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 6 中的图像 3,3
    • After you cut through the adhesive around the entire perimeter of the back cover, begin to lift it away from the phone.
    • Use an opening pick to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    询问修复机器人
  7. Huawei Mate 10 Screen Replacement, Prep the phone for a new back cover: 步骤 7 中的图像 1,2 Huawei Mate 10 Screen Replacement, Prep the phone for a new back cover: 步骤 7 中的图像 2,2
    • Before you install a replacement back cover, be sure to remove all traces of perimeter adhesive from the phone frame.
    • If you are re-using the back cover, carefully remove all traces of adhesive from the back cover.
    • The glass back cover is fragile and prone to cracking. Don't apply uneven pressure to the back cover as you clean.
    • You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
    询问修复机器人
  8. Huawei Mate 10 Screen Replacement: 步骤 8 中的图像 1,2 Huawei Mate 10 Screen Replacement: 步骤 8 中的图像 2,2
    • If your replacement back cover did not come with a flash diffuser or camera bezel, you will need to transfer them from your old cover to the new one.
    • Apply a heated iOpener directly over the bezels for a minute.
    • Use an opening pick to slice around the flash diffuser to loosen the adhesive.
    • The flash diffuser is made of plastic and cracks easily. Be sure to slice around the flash completely before you pry it off.
    • Use an opening tool to pry up and remove the camera bezel.
    • Transfer the parts to your replacement cover.
    询问修复机器人
  9. Huawei Mate 10 Screen Replacement, Remove the plastic bracket: 步骤 9 中的图像 1,2 Huawei Mate 10 Screen Replacement, Remove the plastic bracket: 步骤 9 中的图像 2,2
    • The next two steps show how to remove the heat dissipation layer, along with its plastic bracket.
    • Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
    • One screw lies beneath a white sticker. Remove the sticker.
    • Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
    询问修复机器人
  10. Huawei Mate 10 Screen Replacement: 步骤 10 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 10 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 10 中的图像 3,3
    • Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
    • Pull the plastic bracket away from the top edge of the phone.
    • Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
    • Remove the plastic bracket along with the heat dissipation layer.
    询问修复机器人
  11. Huawei Mate 10 Screen Replacement, Disconnect the battery: 步骤 11 中的图像 1,2 Huawei Mate 10 Screen Replacement, Disconnect the battery: 步骤 11 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    询问修复机器人
  12. Huawei Mate 10 Screen Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 1,2 Huawei Mate 10 Screen Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Huawei Mate 10 Screen Replacement: 步骤 13 中的图像 1,2 Huawei Mate 10 Screen Replacement: 步骤 13 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the fingerprint extension cable from its motherboard socket.
    询问修复机器人
  14. Huawei Mate 10 Screen Replacement, Disconnect the button connector: 步骤 14 中的图像 1,1
    • Use the point of a spudger to pry up and disconnect the button connector from its motherboard socket.
    询问修复机器人
  15. Huawei Mate 10 Screen Replacement, Remove the glued-in battery: 步骤 15 中的图像 1,2 Huawei Mate 10 Screen Replacement, Remove the glued-in battery: 步骤 15 中的图像 2,2
    • The battery is held in place by very strong adhesive.
    • Apply a heated iOpener to the left side of the phone screen for a minute.
    • While you wait, note where the U-shaped adhesive resides on the phone frame.
    询问修复机器人
  16. Huawei Mate 10 Screen Replacement: 步骤 16 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 16 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 16 中的图像 3,3
    • Insert an opening pick in the notch on the phone's right edge.
    • Slowly but firmly push the pick underneath the battery, to loosen it from the frame.
    • If you are having trouble getting the pick under the battery, you can apply some high concentration isopropyl alcohol to the seam. Give the alcohol a minute to penetrate and soften the adhesive.
    询问修复机器人
  17. Huawei Mate 10 Screen Replacement: 步骤 17 中的图像 1,2 Huawei Mate 10 Screen Replacement: 步骤 17 中的图像 2,2
    • Slowly insert an opening pick in the top edge of the battery, towards the right edge.
    • Twist slightly to help loosen the battery.
    询问修复机器人
  18. Huawei Mate 10 Screen Replacement: 步骤 18 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 18 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 18 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Insert a plastic card under the battery's right edge.
    • Push the card inwards to loosen the battery from the frame.
    • If you're having a hard time loosening the battery, you can apply more isopropyl alcohol, or try to soften the adhesive with more heat.
    • Try not to deform the battery as you pry.
    询问修复机器人
  19. Huawei Mate 10 Screen Replacement: 步骤 19 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 19 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 19 中的图像 3,3
    • Once the battery is sufficiently loosened from the frame, slowly lift it out.
    • Remove the battery.
    • To install a replacement battery:
    • Apply new adhesive to the phone frame.
    • Gently lay the battery pack in the phone.
    • Temporarily reconnect the battery to the motherboard to ensure that the battery is properly aligned.
    • Once the battery is aligned, press it firmly in place with your fingers. Disconnect the battery from the motherboard, and resume re-assembly.
    • For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
    询问修复机器人
  20. Huawei Mate 10 Screen Replacement, Remove the loudspeaker: 步骤 20 中的图像 1,2 Huawei Mate 10 Screen Replacement, Remove the loudspeaker: 步骤 20 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the white antenna cable from the bottom of the phone.
    询问修复机器人
  21. Huawei Mate 10 Screen Replacement: 步骤 21 中的图像 1,1
    • Remove the six 3.4 mm Phillips screws holding the loudspeaker in place.
    询问修复机器人
  22. Huawei Mate 10 Screen Replacement: 步骤 22 中的图像 1,2 Huawei Mate 10 Screen Replacement: 步骤 22 中的图像 2,2
    • The loudspeaker is still held in place by adhesive and clips.
    • Insert an opening pick underneath the right edge of the loudspeaker assembly.
    • Carefully slide the opening pick under the right half of the assembly to loosen the clips.
    询问修复机器人
  23. Huawei Mate 10 Screen Replacement: 步骤 23 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 23 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 23 中的图像 3,3
    • Grasp the loosened edge of the loudspeaker and gently pull the assembly away from the bottom edge of the phone.
    • You may need to wiggle the assembly a little to loosen it from the frame.
    • Remove the loudspeaker.
    询问修复机器人
  24. Huawei Mate 10 Screen Replacement, Remove the daughterboard: 步骤 24 中的图像 1,3 Huawei Mate 10 Screen Replacement, Remove the daughterboard: 步骤 24 中的图像 2,3 Huawei Mate 10 Screen Replacement, Remove the daughterboard: 步骤 24 中的图像 3,3
    • Insert the point of a spudger in one of the notches along the bottom edge of the daughterboard.
    • Push the daughterboard away from the bottom of the phone to loosen the board.
    • Repeat the process with a second notch to fully release the daughterboard.
    询问修复机器人
  25. Huawei Mate 10 Screen Replacement: 步骤 25 中的图像 1,1
    • Remove the daughterboard.
    询问修复机器人
  26. Huawei Mate 10 Screen Replacement, Disconnect the screen cable: 步骤 26 中的图像 1,2 Huawei Mate 10 Screen Replacement, Disconnect the screen cable: 步骤 26 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket.
    询问修复机器人
  27. Huawei Mate 10 Screen Replacement: 步骤 27 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 27 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 27 中的图像 3,3
    • Grasp the display cable with your fingers and gently pull it away from the phone frame.
    询问修复机器人
  28. Huawei Mate 10 Screen Replacement, Disconnect the fingerprint sensor cable: 步骤 28 中的图像 1,3 Huawei Mate 10 Screen Replacement, Disconnect the fingerprint sensor cable: 步骤 28 中的图像 2,3 Huawei Mate 10 Screen Replacement, Disconnect the fingerprint sensor cable: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to peel the tape covering the fingerprint sensor cable connector near the bottom edge of the phone.
    • The cable is held in place with a ZIF socket.
    • Use the point of a spudger to flip up the gray bar on the socket to unlock the cable.
    询问修复机器人
  29. Huawei Mate 10 Screen Replacement: 步骤 29 中的图像 1,2 Huawei Mate 10 Screen Replacement: 步骤 29 中的图像 2,2
    • Use tweezers to grasp the cable's brown pull tab and pull the cable out of the socket.
    • To reinstall the fingerprint sensor cable:
    • Align and push the cable back into the connector, up to the white line marked on the cable.
    • Carefully flip the gray bar on the socket down to lock the cable in place.
    询问修复机器人
  30. Huawei Mate 10 Screen Replacement, Remove the screen: 步骤 30 中的图像 1,1
    • The next steps show how to remove the heavily glued screen from the phone. While it is possible to replace the top glass alone, it is very difficult to accomplish without damaging the LCD.
    • Apply a heated iOpener to the left edge of the phone for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used. Since you don't need to worry about overheating the battery or screen, you can apply more heat than usual.
    询问修复机器人
  31. Huawei Mate 10 Screen Replacement: 步骤 31 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 31 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 31 中的图像 3,3
    • Place a suction cup near the bottom left corner of the phone. The edge there has slightly thinner adhesive.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert an opening pick in the gap.
    • Depending on how old your phone is, creating this initial gap may be very difficult. Here are some things you can try if you're having trouble:
    • Repeat the heating and pulling process multiple times to soften the adhesive.
    • Use a playing card instead of an opening pick to insert in the gap.
    • Try heating and prying at a different location.
    • Use a Jimmy to make the initial entry. Be careful working with metal tools, as they will scratch the frame and chip the glass screen.
    询问修复机器人
  32. Huawei Mate 10 Screen Replacement: 步骤 32 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 32 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 32 中的图像 3,3
    • Once you've made the initial entry, slice through the left, top, and right phone edges. Apply heat to help soften the adhesive.
    • The top edge has adhesive that's as thick as the bezel. Make sure to slice through all of the adhesive.
    询问修复机器人
  33. Huawei Mate 10 Screen Replacement: 步骤 33 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 33 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 33 中的图像 3,3
    • As you slice through the bottom edge, be careful not to slice near the right edge of the fingerprint sensor. It contains the sensor ribbon, which is prone to damage.
    • Slice through the bottom edge of the phone, making sure to skip the fingerprint sensor area as marked.
    询问修复机器人
  34. Huawei Mate 10 Screen Replacement: 步骤 34 中的图像 1,3 Huawei Mate 10 Screen Replacement: 步骤 34 中的图像 2,3 Huawei Mate 10 Screen Replacement: 步骤 34 中的图像 3,3
    • Once you have sliced around the perimeter, grasp the screen from the top corners and lift up.
    • Use an opening pick to slice through any remaining adhesive holding onto the screen.
    • Carefully thread the fingerprint sensor cable and the display cable through their respective cutouts in the phone's frame.
    询问修复机器人
  35. Huawei Mate 10 Screen Replacement: 步骤 35 中的图像 1,1
    • Remove the screen.
    • You may need to transfer the fingerprint sensor to your new screen. Follow the next step to remove the fingerprint sensor.
    询问修复机器人
  36. Huawei Mate 10 Screen Replacement, Remove the fingerprint sensor: 步骤 36 中的图像 1,3 Huawei Mate 10 Screen Replacement, Remove the fingerprint sensor: 步骤 36 中的图像 2,3 Huawei Mate 10 Screen Replacement, Remove the fingerprint sensor: 步骤 36 中的图像 3,3
    • Position your finger or the flat end of a spudger on the fingerprint sensor's backside and push gently to dislodge the sensor.
    • Carefully thread the sensor cable through the screen's cutout.
    • Remove the fingerprint sensor.
    询问修复机器人
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
8等其他人完成本指南。
Arthur Shi
于01/03/18注册
336,141 声望
创作了848篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了25,799篇指南
3指南评论
Bjr alors je vient de changer l'écran sur mon Huawei mate 10 pro… LeLe problème c'est qu'il faut appuyer plusieurs fois sur le bouton power pour que l'écran afficher je sais pas où il est le problème pouvait vous m'aide et merci
Benbouali houmame - 回复 分享
thank you, for this information........... definately sending mine to the professionals.
Murray Reid - 回复 分享
شكرا. جيدجدا. اتمنى اكثر
arkank018 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 122
总计 9,894
