Huawei Mate 10 Pro Camera Assembly Replacement
简介
转到步骤 1There may be occasions where it is necessary to access the camera assembly of the Huawei Mate Pro 10. Whether it be for maintenance or replacement, this guide will show the steps needed to safely access and remove the assembly from the motherboard.
Insert a SIM opening tool in the hole on the left side and push it in.
Remove the SIM card tray.
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
在这个步骤中使用的工具:Halberd Spudger$2.99
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
在这个步骤中使用的工具:Tweezers$4.99
Unscrew screws on black cover and remove using tweezers to leverage.
On the backside of the motherboard assembly, detach the camera assembly from the motherboard.
2等其他人完成本指南。
