跳转到主内容
How to replace the extension handle on my trolley?
VAUDE Reparaturteam
VAUDE Reparaturteam 另一个贡献者
最后更新于 July 23, 2019
10分钟
简单
特色指南
社区贡献指南
You can use these instructions for almost all VAUDE trolleys and replace the handle yourself. For our models Futuna, Rotuma, Turin and Tuvana, however, we recommend you ask a repair specialists at VAUDE to do the replacement.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. How to replace the extension handle on my trolley?, Trolley handle: 步骤 1 中的图像 1,1
    • Open the zip inside the trolley to expose the handle.
  2. How to replace the extension handle on my trolley?: 步骤 2 中的图像 1,2 How to replace the extension handle on my trolley?: 步骤 2 中的图像 2,2
    • Unscrew the two screws in the lower section on the handle assembly using a Phillips screwdriver.
  3. How to replace the extension handle on my trolley?: 步骤 3 中的图像 1,3 How to replace the extension handle on my trolley?: 步骤 3 中的图像 2,3 How to replace the extension handle on my trolley?: 步骤 3 中的图像 3,3
    • Using a Phillips screwdriver, unscrew the 6 marked screws attaching the handle to the upper section.
  4. How to replace the extension handle on my trolley?: 步骤 4 中的图像 1,2 How to replace the extension handle on my trolley?: 步骤 4 中的图像 2,2
    • After unscrewing all screws, it is easy to remove the entire handle assembly.
结论
Follow the instructions in reverse order, to complete the repair/replacement.
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
团队
Vaudesport Vaudesport 的会员
Community
3 名成员
创作了97篇指南
1指南评论
so I take it from this that we’re screwed if the top bit is riveted (which is quite common by the way!)
Steven Moschidis - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 46
过去 30 天: 172
总计 14,144
