How to repair a broken potentiometer or pot
简介
转到步骤 1This shows how to repair a guitar pot instead of having to replace it with a new one. I was able to fix mine instead of having to take it to a repair shop.
Before you begin be sure to disconnect all cables from the Electric Guitar (mine is a Fender) and read safety precautions. You will have to de-solder some wires before you can remove the pot. Take photos before starting so you know where each wire goes when you reassemble.
Once you have removed the affected pot (potentiometer) from the guitar, set it on a stable surface. Take photos or make note of how everything fits together so you put it all back together the same way. I also made marks to help. Bend back the tabs that hold it together as shown in the photo.
Next start to align the loose piece (black plastic) over the end of the stem. You will have to align the hole in the black plastic piece with the end of the stem. The brown fiberboard piece must be in between at this point. Also note how the small tab on the metal stem holder is not quite matching up with its slot in the fiberboard. See next photo
Here the metal stem holder is properly aligned with the fiberboard. This is important because all three pieces must be aligned in order for it to go back together completely. Carefully align the hole in the black plastic piece with the slot on the end of the stem and get it started by pressing down on the black piece till it begins to go together.
Find a hard surface to do the next step on. I used a cloth to help stabilize the pot. Note the end of the slotted stem inside the hole of the black plastic piece. It is correctly lined up and just beginning to go into the hole. It will fit very tightly. use a finger to press down more while keeping everything aligned. Takes a lot of pressure.
Take you time and work it gradually until the end of the stem is well inserted in the hole of the black plastic piece. Keep checking to see that all three pieces are still properly aligned. Note that now the stem is more visible above the surface of the black plastic and all 3 pieces are still aligned correctly. At this point it is assembled.
You are ready to put it back into the back of the pot. Note the tab inside the metal pot backing. You'll have to put it back in the same alignment that it was in before disassembly. also the plastic tab on the black plastic piece will need to go to either side of the metal tab otherwise you won't be able to put the metal backing on. See next.
Here you see the black tab previously mentioned. Put the two pieces together that you see in the photo in the same alignment that they were before disassembly. Turn the stem either to the left or right so the metal tab in the backing and the black tab are not directly on top of one another and everything should go together tightly. See next.
Replace the pot back into the guitar pickguard so it is in its proper alignment on the guitar. Begin to reattach any de-soldered connections. Mine needed two wires reattached. Put yours back together so they are the same as they were before you began disassembly. Refer to your initial photos or diagram.
另外一个人完成了本指南。
5条评论
The repair is open to interpretation, like the Geneva Convention
This was not a repair video.
This is how to repair when the stem pulls out of the wiper driver (black plastic bit with slot). If that has not happened, you do not need this. When it HAS happened (grumble grumble) this video saves ordering a new potentiometer. Or, in my case, all three. Thanks, Chinese Squier factory :rolleyes:.
