跳转到主内容
How to Use the Anti-Static Wrist Strap
你所需要的
  1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: 步骤 1 中的图像 1,2 How to Use the Anti-Static Wrist Strap, Remove any jewelry: 步骤 1 中的图像 2,2
    • Before you begin, remove any jewelry from your wrist and fingers.
  2. How to Use the Anti-Static Wrist Strap, Adjust the strap: 步骤 2 中的图像 1,2 How to Use the Anti-Static Wrist Strap, Adjust the strap: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    $7.95
    • The anti-static strap should be adjusted to fit snugly on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  3. How to Use the Anti-Static Wrist Strap: 步骤 3 中的图像 1,2 How to Use the Anti-Static Wrist Strap: 步骤 3 中的图像 2,2
    • To tighten the strap, pull the looped end away from the plastic slide.
  4. How to Use the Anti-Static Wrist Strap: 步骤 4 中的图像 1,2 How to Use the Anti-Static Wrist Strap: 步骤 4 中的图像 2,2
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  5. How to Use the Anti-Static Wrist Strap: 步骤 5 中的图像 1,2 How to Use the Anti-Static Wrist Strap: 步骤 5 中的图像 2,2
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  6. How to Use the Anti-Static Wrist Strap: 步骤 6 中的图像 1,2 How to Use the Anti-Static Wrist Strap: 步骤 6 中的图像 2,2
    • Attach the metal clip to one of the grounding nodes on an Anti-Static Mat or a grounded metal surface.
  7. How to Use the Anti-Static Wrist Strap: 步骤 7 中的图像 1,1
    • You're now ready to repair.
    • During your repair, be mindful of the strap's cable, as stretching it too far can cause the clip to unsnap.
结论
For other general electronics skills guides, click here.
48等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
214,168 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
7指南评论
J'ai un doute…
Retirer tout bijou/montre/whatever, mais uniquement sur la main où l'on met le bracelet (ce qui me paraît logique) ou bien des deux mains ?
Yacou - 回复
peut ton se connecter direct ex: sur une prise éléctrique avec l'embout terre de la prise
Lucka Lellig - 回复
Bonjour @luckalellig non, ceci est fortement déconseillé !! Le courant des prises électriques est trop fort et risquerait de vous électrocuter.
Claire Miesch -
non la terre pas ce branche au pole positif et négatif
Lucka Lellig - 回复
Si vous êtes sûre que votre prise est réellement reliée à la terre (ce n'est souvent pas le cas dans les immeubles anciens, ils peuvent une prise de terre reliée à rien) oui la fiche terre (la fiche qui sort de la prise, surtout pas les trous qui sont la phase et le neutre et qui pourraient vous électrocuter - je précise car la réponse précédente semble confondre) sera parfaite.
Marcanpilami -
添加评论
浏览统计数据:
过去 24 小时: 35
过去 7 天: 376
过去 30 天: 1,560
总计 59,569
