跳转到主内容
How to Use the Portable Anti-Static Mat
你所需要的
  1. How to Use the Portable Anti-Static Mat, Unfold the mat: 步骤 1 中的图像 1,3 How to Use the Portable Anti-Static Mat, Unfold the mat: 步骤 1 中的图像 2,3 How to Use the Portable Anti-Static Mat, Unfold the mat: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    $39.95
    • Unfold your anti-static mat and spread it out on your work area.
    • Make sure the iFixit logo is facing upward.
  2. How to Use the Portable Anti-Static Mat, Attach the black grounding wire: 步骤 2 中的图像 1,2 How to Use the Portable Anti-Static Mat, Attach the black grounding wire: 步骤 2 中的图像 2,2
    • Place the black grounding wire's connector over one of the mat's grounding nodes.
    • Press down on the connector until you hear a click to secure it to the mat.
  3. How to Use the Portable Anti-Static Mat: 步骤 3 中的图像 1,2 How to Use the Portable Anti-Static Mat: 步骤 3 中的图像 2,2
    • Attach the black grounding wire's clip to a grounded metal surface.
    • To ensure a good grip on the surface, pinch hard on the clip's levers to open the jaws wide.
  4. How to Use the Portable Anti-Static Mat: 步骤 4 中的图像 1,2 How to Use the Portable Anti-Static Mat: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
  5. How to Use the Portable Anti-Static Mat, Adjust the strap: 步骤 5 中的图像 1,2 How to Use the Portable Anti-Static Mat, Adjust the strap: 步骤 5 中的图像 2,2
    • The anti-static strap should be adjusted to fit snug on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  6. How to Use the Portable Anti-Static Mat: 步骤 6 中的图像 1,2 How to Use the Portable Anti-Static Mat: 步骤 6 中的图像 2,2
    • To tighten the strap, pull the looped end away from the plastic slide.
  7. How to Use the Portable Anti-Static Mat: 步骤 7 中的图像 1,2 How to Use the Portable Anti-Static Mat: 步骤 7 中的图像 2,2
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  8. How to Use the Portable Anti-Static Mat: 步骤 8 中的图像 1,2 How to Use the Portable Anti-Static Mat: 步骤 8 中的图像 2,2
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  9. How to Use the Portable Anti-Static Mat, Plug in the strap: 步骤 9 中的图像 1,2 How to Use the Portable Anti-Static Mat, Plug in the strap: 步骤 9 中的图像 2,2
    • Disconnect the strap's metal clip from the rest of the blue grounding wire.
  10. How to Use the Portable Anti-Static Mat: 步骤 10 中的图像 1,2 How to Use the Portable Anti-Static Mat: 步骤 10 中的图像 2,2
    • Insert the tip of the blue grounding wire into one of the black grounding wire's sockets.
  11. How to Use the Portable Anti-Static Mat: 步骤 11 中的图像 1,1
    • Place your device on the mat.
    • You're now ready for repairs!
    • Throughout the repair, keep the device centered on the mat to minimize ESD.
结论
For other general electronics skills guides, click here.
32等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,742 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,735篇指南
9指南评论
What else can the mat be grounded to, as I don't have a metal desk.
Cringe_Master245 - 回复
Hi there.
Technically, you can ground yourself to any large, metal object that is touching the ground. If you don't have any in your vicinity, then you can clip the wire to the middle screw in your outlet or plug the wire into the bottom-most ground slot in the outlet.
Alex Diaz-Kokaisl -
What can it be grounded to if I don't have a metal desk and am in Europe? There is no middle screw or ground slot, at least where I live.
Pyuukin - 回复
Double check your outlets, it's possible that a ground adapter plug like the following one will work for you.
Europlug example:
https://eleshop.eu/esd-earthing-plug.htm...
UK example:
https://www.vodex.co.uk/product/esd-eart...
If you don't have any grounded outlets in your home, you might consider connecting your mat to a nearby radiator (assuming that your plumbing is metal).
Alexander Jadczak -
How can you flatten the anti static mat?
Charley - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 163
过去 30 天: 722
总计 31,615
