跳转到主内容
加入维修社区 - 创建账户
How to Use Suction Tape
  1. How to Use Suction Tape, Choose the tape: 步骤 1 中的图像 1,2 How to Use Suction Tape, Choose the tape: 步骤 1 中的图像 2,2
    • If you want to secure one side of your two-panel device, skip to this step.
    • If you want to buffer a difficult surface on your device, move to the next step.
    询问修复机器人
    添加评论
  2. How to Use Suction Tape, Measure the tape: 步骤 2 中的图像 1,3 How to Use Suction Tape, Measure the tape: 步骤 2 中的图像 2,3 How to Use Suction Tape, Measure the tape: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • Measure the length of tape you want and mark it with a pen. Consider the following:
    • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
    • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
    询问修复机器人
    添加评论
  3. How to Use Suction Tape, Cut the tape: 步骤 3 中的图像 1,3 How to Use Suction Tape, Cut the tape: 步骤 3 中的图像 2,3 How to Use Suction Tape, Cut the tape: 步骤 3 中的图像 3,3
    • Use scissors to cut the tape to the desired length.
    • Repeat the measuring and cutting procedure for each piece of tape required.
    询问修复机器人
    添加评论
  4. How to Use Suction Tape, Peel the tape: 步骤 4 中的图像 1,2 How to Use Suction Tape, Peel the tape: 步骤 4 中的图像 2,2
    • Peel the tape off its plastic liner.
    询问修复机器人
    添加评论
  5. How to Use Suction Tape, Apply the tape: 步骤 5 中的图像 1,3 How to Use Suction Tape, Apply the tape: 步骤 5 中的图像 2,3 How to Use Suction Tape, Apply the tape: 步骤 5 中的图像 3,3
    • Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
    询问修复机器人
    添加评论
  6. How to Use Suction Tape, Secure the tape: 步骤 6 中的图像 1,3 How to Use Suction Tape, Secure the tape: 步骤 6 中的图像 2,3 How to Use Suction Tape, Secure the tape: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
    • Use a spudger to press out any large bubbles.
    询问修复机器人
    添加评论
  7. How to Use Suction Tape, Open the device: 步骤 7 中的图像 1,2 How to Use Suction Tape, Open the device: 步骤 7 中的图像 2,2
    • Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
    • You're now ready to open your device!
    • Follow this guide for general instructions on how to use the Anti-Clamp.
    询问修复机器人
    添加评论
  8. How to Use Suction Tape, Measure the tape: 步骤 8 中的图像 1,3 How to Use Suction Tape, Measure the tape: 步骤 8 中的图像 2,3 How to Use Suction Tape, Measure the tape: 步骤 8 中的图像 3,3
    • The remaining steps show how to secure one side of your two-panel device.
    • Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
    • In this example, we want to open the screen, so we'll secure the blue back cover.
    • You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
    • Use enough tape to ensure a good hold on the panel you don't want to open.
    • Don't cover the power button with tape, or you might accidentally turn on the device.
    询问修复机器人
    添加评论
  9. How to Use Suction Tape, Peel the tape: 步骤 9 中的图像 1,2 How to Use Suction Tape, Peel the tape: 步骤 9 中的图像 2,2
    询问修复机器人
    添加评论
  10. How to Use Suction Tape, Cut the tape: 步骤 10 中的图像 1,2 How to Use Suction Tape, Cut the tape: 步骤 10 中的图像 2,2
    询问修复机器人
    添加评论
  11. How to Use Suction Tape, Apply the tape: 步骤 11 中的图像 1,3 How to Use Suction Tape, Apply the tape: 步骤 11 中的图像 2,3 How to Use Suction Tape, Apply the tape: 步骤 11 中的图像 3,3
    • Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
    • Don't fold the tape over the panel you want to open, as this might hinder the opening procedure.
    询问修复机器人
    添加评论
  12. How to Use Suction Tape, Fold the tape: 步骤 12 中的图像 1,3 How to Use Suction Tape, Fold the tape: 步骤 12 中的图像 2,3 How to Use Suction Tape, Fold the tape: 步骤 12 中的图像 3,3
    • Fold the tape onto the panel you don't want to open.
    • Use your fingers to press down the tape and firmly secure it to your device.
    询问修复机器人
    添加评论
  13. How to Use Suction Tape, Open the device: 步骤 13 中的图像 1,2 How to Use Suction Tape, Open the device: 步骤 13 中的图像 2,2
    询问修复机器人
    添加评论
结论
For other general electronics skills guides, click here.
取消:我没有完成这个指南。
7等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
244,856 声望
创作了1,203篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,236篇指南
3指南评论
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
Arturo - 回复 分享
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
Kevin Smith - 回复 分享
I would like to check the material of this product. Anyone can help me?
Nguyễn Thị Vân Anh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 63
过去 30 天: 298
总计 11,920
