跳转到主内容
How to Replace the Screen Adhesive for Your Google Pixel 7 Pro
你所需要的
  1. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: 步骤 1 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: 步骤 1 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • Any residual adhesive or debris will prevent your screen from sealing properly.
    • Use the flat end of your spudger to scrape off as much adhesive as you can.
    • Use tweezers or your fingers to peel and remove any remaining adhesive.
    • Take care not to puncture the battery with your tweezers—a punctured battery may leak dangerous chemicals or cause a fire.
    • Clean the perimeter of the frame with a small amount of highly-concentrated isopropyl alcohol (over 90%) and a lint-free or microfiber cloth.
  2. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: 步骤 2 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: 步骤 2 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: 步骤 2 中的图像 3,3
    • If you're reusing your screen, clean it as you did for the frame.
  3. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Orient the adhesive: 步骤 3 中的图像 1,2 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Orient the adhesive: 步骤 3 中的图像 2,2
    • Before applying the new adhesive, lay it over the frame to find its proper orientation.
    • Use features such as the front-facing camera, upper loudspeaker, and corner notches to orient the adhesive.
  4. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the adhesive backing: 步骤 4 中的图像 1,1
    • Use the pull tab on the top of the adhesive to remove the clear protective backing.
  5. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: 步骤 5 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: 步骤 5 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: 步骤 5 中的图像 3,3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lay the adhesive onto the frame, starting with the bottom edge. Make small corrections as you go.
    • Use the bottom left notch, top right notch, and upper loudspeaker cutout to help align the adhesive.
  6. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 步骤 6 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 步骤 6 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 步骤 6 中的图像 3,3
    • Use a spudger or your fingers to firmly press along the perimeter of the adhesive and adhere it to the frame.
  7. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: 步骤 7 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: 步骤 7 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: 步骤 7 中的图像 3,3
    • Grab the pull tab on the lower right of the frame and peel off the main liner.
    • There's a smaller liner under this one. Don't remove it yet.
  8. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Check for liners: 步骤 8 中的图像 1,1
    • Check the front-facing camera hole and sensor cutout on the replacement screen and remove any remaining protective liners in it.
  9. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Continue reassembly: 步骤 9 中的图像 1,1
    • Return to your phone's guide and continue reassembly.
    • Remember to reinstall the display cable bracket.
    • Finish this guide when your screen is installed and you're ready to seal the phone up.
  10. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 步骤 10 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 步骤 10 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 步骤 10 中的图像 3,3
    • Grab the pull tab on the upper left of the frame and remove the liner covering the perimeter adhesive.
    • Make sure the adhesive doesn't peel up with the liner.
  11. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Install the screen: 步骤 11 中的图像 1,2 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Install the screen: 步骤 11 中的图像 2,2
    • Flip the screen over and lay it onto the frame.
    • Press along the perimeter of the screen to secure it.
  12. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: 步骤 12 中的图像 1,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: 步骤 12 中的图像 2,3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    Screen Vise Clamps 6-Pack
    $15.99
    购买
    • To evenly compress your Pixel and strengthen the bond of the screen to the frame, you need to account for the camera bar.
    • If you have screen vise clamps, you can work around the camera bar. Secure the clamps to the perimeter of the device.
    • Apply tape to the perimeter of your rear glass to protect its finish.
    • Place coins or similarly thick objects along the edges of the rear glass. Make sure they're as thick or thicker than the camera bar.
    • Stack multiple books or other heavy objects on your phone. Leave them in place for thirty minutes or longer. Ideally, leave them stacked overnight.
终点
30等其他人完成本指南。
Arthur Shi
于01/03/18注册
253,469 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 117
过去 30 天: 745
总计 11,201
