跳转到主内容
How to Replace Keys on a Keyboard
Cooper
Cooper5 其他贡献者
最后更新于 September 16, 2024
10 - 20 分钟
简单
Do you have a keyboard with keys that do not work? Use this guide to replace your keys and return your keyboard to proper working condition.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. How to Replace Keys on a Keyboard, Individual Keys: 步骤 1 中的图像 1,2 How to Replace Keys on a Keyboard, Individual Keys: 步骤 1 中的图像 2,2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: 步骤 2 中的图像 1,2 How to Replace Keys on a Keyboard: 步骤 2 中的图像 2,2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: 步骤 4 中的图像 1,1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: 步骤 5 中的图像 1,2 How to Replace Keys on a Keyboard: 步骤 5 中的图像 2,2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
结论
Congratulations! You now have a keyboard with fully functional keys!
6等其他人完成本指南。
Cooper
于02/24/15注册
457 声望
创作了2篇指南
团队
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 的会员
CPSU-GREEN-W15S24G6
4 名成员
创作了15篇指南
2条评论
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - 回复
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 48
过去 30 天: 144
总计 18,751
