跳转到主内容
How to Repair a Hole in an Inflatable Floatie
Selena Barnhart
Selena Barnhart 另一个贡献者
最后更新于 July 29, 2024
30 - 45 分钟
简单
If your floatie is slowly deflating then you probably punctured it. This guide will help you repair the punctured area and get you back in the water.
Before using this guide, check the valve stem to insure it is securely closed and not the cause of the inflating. If it is not the case then proceed with this guide.
Step 4 requires you to use scissors so please be cautious when cutting the waterproof tape.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 步骤 1 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 步骤 1 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 步骤 1 中的图像 3,3
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: 步骤 2 中的图像 1,2 How to Repair a Hole in an Inflatable Floatie: 步骤 2 中的图像 2,2
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: 步骤 3 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie: 步骤 3 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie: 步骤 3 中的图像 3,3
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: 步骤 4 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie: 步骤 4 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie: 步骤 4 中的图像 3,3
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: 步骤 5 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie: 步骤 5 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie: 步骤 5 中的图像 3,3
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: 步骤 6 中的图像 1,2 How to Repair a Hole in an Inflatable Floatie: 步骤 6 中的图像 2,2
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
结论
Enjoy your renewed floatie!
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 58
过去 30 天: 172
总计 1,317
