跳转到主内容
How to Disable Auto Boot
  1. How to Disable Auto Boot, How to Disable Auto Boot: 步骤 1 中的图像 1,3 How to Disable Auto Boot, How to Disable Auto Boot: 步骤 1 中的图像 2,3 How to Disable Auto Boot, How to Disable Auto Boot: 步骤 1 中的图像 3,3
    • Power on your Mac and launch Terminal.
    • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
  2. How to Disable Auto Boot: 步骤 2 中的图像 1,2 How to Disable Auto Boot: 步骤 2 中的图像 2,2
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return].
    • Your [return] key may also be labeled ⏎ or [enter].
    • If you are prompted for an administrative password, type the password and press [return].
    • Your password will not be displayed in Terminal.
  3. How to Disable Auto Boot: 步骤 3 中的图像 1,1
    • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • Remember, you must still disconnect the battery before servicing internal components.
  4. How to Disable Auto Boot: 步骤 4 中的图像 1,3 How to Disable Auto Boot: 步骤 4 中的图像 2,3 How to Disable Auto Boot: 步骤 4 中的图像 3,3
    • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
    • sudo nvram AutoBoot=%03
    • Press [return].
    • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
结论
Congrats! You're done.
49等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
418,675 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Community
136 名成员
创作了15,177篇指南
15条评论
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - 回复
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - 回复
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - 回复
This code change DOES NOT work.
MFMauceri - 回复
This was a great help to replace my MacBook Pro battery. Great step by step explanations. I received kit and followed the directions.
Simon Tezzo - 回复
添加评论
浏览统计数据:
过去 24 小时: 93
过去 7 天: 634
过去 30 天: 2,925
总计 110,118
