跳转到主内容
加入维修社区 - 创建账户
HTC Vive OLED Screen Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. HTC Vive OLED Screen Replacement, Release the upper head strap: 步骤 1 中的图像 1,2 HTC Vive OLED Screen Replacement, Release the upper head strap: 步骤 1 中的图像 2,2
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
    询问修复机器人
    添加评论
  2. HTC Vive OLED Screen Replacement, Remove the upper head strap: 步骤 2 中的图像 1,2 HTC Vive OLED Screen Replacement, Remove the upper head strap: 步骤 2 中的图像 2,2
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
    询问修复机器人
    添加评论
  3. HTC Vive OLED Screen Replacement, Remove the right side of the head strap: 步骤 3 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the right side of the head strap: 步骤 3 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the right side of the head strap: 步骤 3 中的图像 3,3
    • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
    • Slide the right side of the head strap through its metal loop to remove it.
    询问修复机器人
    添加评论
  4. HTC Vive OLED Screen Replacement, Remove the left side of the head strap: 步骤 4 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the left side of the head strap: 步骤 4 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the left side of the head strap: 步骤 4 中的图像 3,3
    • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
    • Slide the left side of the head strap through its metal loop to remove it.
    询问修复机器人
    添加评论
  5. HTC Vive OLED Screen Replacement, Remove the head strap: 步骤 5 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the head strap: 步骤 5 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the head strap: 步骤 5 中的图像 3,3
    • Slide the head strap along the cable, away from the Vive.
    • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
    询问修复机器人
    添加评论
  6. HTC Vive OLED Screen Replacement, Unscrew the head strap mounts: 步骤 6 中的图像 1,2 HTC Vive OLED Screen Replacement, Unscrew the head strap mounts: 步骤 6 中的图像 2,2
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
    添加评论
  7. HTC Vive OLED Screen Replacement, Remove the head strap mounts: 步骤 7 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the head strap mounts: 步骤 7 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the head strap mounts: 步骤 7 中的图像 3,3
    • Remove both head strap mounts.
    询问修复机器人
    添加评论
  8. HTC Vive OLED Screen Replacement, Remove the facerest: 步骤 8 中的图像 1,2 HTC Vive OLED Screen Replacement, Remove the facerest: 步骤 8 中的图像 2,2
    • Slide the facerest straight away from the headset to remove it.
    询问修复机器人
    添加评论
  9. HTC Vive OLED Screen Replacement, Unscrew the outer shell: 步骤 9 中的图像 1,3 HTC Vive OLED Screen Replacement, Unscrew the outer shell: 步骤 9 中的图像 2,3 HTC Vive OLED Screen Replacement, Unscrew the outer shell: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
    添加评论
  10. HTC Vive OLED Screen Replacement, Remove the outer shell: 步骤 10 中的图像 1,2 HTC Vive OLED Screen Replacement, Remove the outer shell: 步骤 10 中的图像 2,2
    • Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
    询问修复机器人
    添加评论
  11. HTC Vive OLED Screen Replacement: 步骤 11 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 11 中的图像 2,2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
    • If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
    询问修复机器人
    添加评论
  12. HTC Vive OLED Screen Replacement: 步骤 12 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 12 中的图像 2,2
    • Slide the right side of the outer shell to the right and off of the headset.
    询问修复机器人
    添加评论
  13. HTC Vive OLED Screen Replacement: 步骤 13 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 13 中的图像 2,2
    • Repeat the last three steps for the left side of the outer shell and remove it.
    询问修复机器人
    添加评论
  14. HTC Vive OLED Screen Replacement, Disconnect the sensor array cables: 步骤 14 中的图像 1,3 HTC Vive OLED Screen Replacement, Disconnect the sensor array cables: 步骤 14 中的图像 2,3 HTC Vive OLED Screen Replacement, Disconnect the sensor array cables: 步骤 14 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
    添加评论
  15. HTC Vive OLED Screen Replacement: 步骤 15 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 15 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 15 中的图像 3,3
    • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
    • Slide the cable straight out of its socket on the motherboard.
    添加评论
  16. HTC Vive OLED Screen Replacement: 步骤 16 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 16 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 16 中的图像 3,3
    • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
    添加评论
  17. HTC Vive OLED Screen Replacement: 步骤 17 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 17 中的图像 2,2
    • Use tweezers or a spudger to pry up the camera cable cover and remove it.
    询问修复机器人
    添加评论
  18. HTC Vive OLED Screen Replacement: 步骤 18 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 18 中的图像 2,2
    • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
    询问修复机器人
    添加评论
  19. HTC Vive OLED Screen Replacement, Unscrew the sensor array: 步骤 19 中的图像 1,1
    • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
    询问修复机器人
    添加评论
  20. HTC Vive OLED Screen Replacement: 步骤 20 中的图像 1,1
    • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
    添加评论
  21. HTC Vive OLED Screen Replacement: 步骤 21 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 21 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #000 Screwdriver
    $5.49
    • You'll need a narrow, long-shaft driver to reach these screws.
    询问修复机器人
    添加评论
  22. HTC Vive OLED Screen Replacement, Remove the sensor array: 步骤 22 中的图像 1,2 HTC Vive OLED Screen Replacement, Remove the sensor array: 步骤 22 中的图像 2,2
    • Lift the sensor array away from the headset to remove it.
    询问修复机器人
    添加评论
  23. HTC Vive OLED Screen Replacement, Disconnect the motherboard: 步骤 23 中的图像 1,3 HTC Vive OLED Screen Replacement, Disconnect the motherboard: 步骤 23 中的图像 2,3 HTC Vive OLED Screen Replacement, Disconnect the motherboard: 步骤 23 中的图像 3,3
    • Remove the tape covering the interconnect cable socket.
    • Use the point of a spudger to flip up the small locking flap on the cable socket.
    • Slide the interconnect cable straight out of its socket on the motherboard.
    询问修复机器人
    添加评论
  24. HTC Vive OLED Screen Replacement: 步骤 24 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 24 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 24 中的图像 3,3
    • Remove the tape covering the left OLED cable socket.
    • Slide the left OLED cable straight out of its socket on the motherboard.
    询问修复机器人
    添加评论
  25. HTC Vive OLED Screen Replacement: 步骤 25 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 25 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 25 中的图像 3,3
    • Remove the tape covering the right OLED cable socket.
    • Slide the right OLED cable straight out of its socket on the motherboard.
    询问修复机器人
    添加评论
  26. HTC Vive OLED Screen Replacement: 步骤 26 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 26 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair tweezers to slightly twist the interconnect cable and press it down until the tabs on either side of the cable clear the hole in the motherboard.
    • During reassembly, make sure to thread the interconnect cable through its slot in the motherboard.
    询问修复机器人
    添加评论
  27. HTC Vive OLED Screen Replacement, Remove the motherboard: 步骤 27 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the motherboard: 步骤 27 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the motherboard: 步骤 27 中的图像 3,3
    • Press the non-port-end of the motherboard toward the top of headset while hinging it away from the midframe to free it from the clips securing that end.
    • Slide the motherboard toward the bottom of the headset, over the clips, to remove it.
    • Take care not to snag any cables during removal.
    询问修复机器人
    添加评论
  28. HTC Vive OLED Screen Replacement, Disconnect the facerest midframe: 步骤 28 中的图像 1,3 HTC Vive OLED Screen Replacement, Disconnect the facerest midframe: 步骤 28 中的图像 2,3 HTC Vive OLED Screen Replacement, Disconnect the facerest midframe: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to peel back the plastic covering the eyepiece midframe cable socket.
    • Use the pointed end of a spudger to flip up the plastic locking flap on the socket.
    • Slide the cable straight out of its socket to remove it.
    询问修复机器人
    添加评论
  29. HTC Vive OLED Screen Replacement: 步骤 29 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 29 中的图像 2,2
    • Gently peel the eyepiece midframe cable off of the facerest midframe.
    询问修复机器人
    添加评论
  30. HTC Vive OLED Screen Replacement, Unscrew the facerest midframe: 步骤 30 中的图像 1,1
    • Use a PH000 driver to remove the four 3.9 mm screws securing the facerest midframe.
    询问修复机器人
    添加评论
  31. HTC Vive OLED Screen Replacement, Remove the facerest midframe: 步骤 31 中的图像 1,2 HTC Vive OLED Screen Replacement, Remove the facerest midframe: 步骤 31 中的图像 2,2
    • Lift the facerest midframe off of the eyepiece midframe.
    询问修复机器人
    添加评论
  32. HTC Vive OLED Screen Replacement, Remove the eyepiece gasket: 步骤 32 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the eyepiece gasket: 步骤 32 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the eyepiece gasket: 步骤 32 中的图像 3,3
    • Gently lift the eyepiece gasket off of the lens and OLED frames to remove it.
    询问修复机器人
    添加评论
  33. HTC Vive OLED Screen Replacement, Remove the support rod: 步骤 33 中的图像 1,3 HTC Vive OLED Screen Replacement, Remove the support rod: 步骤 33 中的图像 2,3 HTC Vive OLED Screen Replacement, Remove the support rod: 步骤 33 中的图像 3,3
    • Pull the rubber bumpers off of either end of the support rod.
    询问修复机器人
    添加评论
  34. HTC Vive OLED Screen Replacement: 步骤 34 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 34 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 34 中的图像 3,3
    • Slide the support rod out of its brackets on the lens and OLED frames.
    询问修复机器人
    添加评论
  35. HTC Vive OLED Screen Replacement, Remove the focus rod: 步骤 35 中的图像 1,1
    • Use a PH000 driver to remove the eight 3.1 mm screws securing the focus rod brackets.
    询问修复机器人
    添加评论
  36. HTC Vive OLED Screen Replacement: 步骤 36 中的图像 1,1
    • Remove the focus rod and its brackets.
    询问修复机器人
    添加评论
  37. HTC Vive OLED Screen Replacement, Unscrew the OLED covers: 步骤 37 中的图像 1,1
    • Use a PH000 driver to remove the eight 2.4 mm screws securing the OLED covers.
    询问修复机器人
    添加评论
  38. HTC Vive OLED Screen Replacement, Remove the OLED covers: 步骤 38 中的图像 1,2 HTC Vive OLED Screen Replacement, Remove the OLED covers: 步骤 38 中的图像 2,2
    • Use the flat end of a spudger push up one edge of the OLED cover and start unclipping that edge.
    询问修复机器人
    添加评论
  39. HTC Vive OLED Screen Replacement: 步骤 39 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 39 中的图像 2,2
    • Slide the spudger under the clip along that edge to free the rest of the edge.
    询问修复机器人
    添加评论
  40. HTC Vive OLED Screen Replacement: 步骤 40 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 40 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 40 中的图像 3,3
    • Slide the spudger around the remaining edges of the OLED cover to unclip those edges.
    询问修复机器人
    添加评论
  41. HTC Vive OLED Screen Replacement: 步骤 41 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 41 中的图像 2,2
    • Remove the OLED cover.
    • Repeat the last three steps to remove the other OLED cover.
    • During reassembly, remember to thread the OLED cables through their slots in the OLED cover.
    询问修复机器人
    添加评论
  42. HTC Vive OLED Screen Replacement, Remove the OLED displays: 步骤 42 中的图像 1,1
    • Very carefully lift the OLED display by its edges out of its frame.
    • If you are reusing the OLED displays, be very careful to avoid touching the front of the displays or bending or cracking the displays.
    • Repeat this process for the other OLED display.
    询问修复机器人
    添加评论
  43. HTC Vive OLED Screen Replacement, Remove the lenses: 步骤 43 中的图像 1,1
    • Apply an iOpener to the lens to soften the adhesive securing it to the frame.
    询问修复机器人
    添加评论
  44. HTC Vive OLED Screen Replacement: 步骤 44 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 44 中的图像 2,2
    • Use an opening tool to pry up the flat edge of the lens.
    • If it's difficult to pry up, apply the iOpener for another 30 seconds to further soften the adhesive.
    询问修复机器人
    添加评论
  45. HTC Vive OLED Screen Replacement, Remove the lens: 步骤 45 中的图像 1,1
    • Remove the lens.
    • Repeat the last two steps to remove the other lens.
    • Only the lens and OLED frames remain.
    • During reassembly, make sure the convex side of the lens is facing away from the frame.
    询问修复机器人
    添加评论
  46. HTC Vive OLED Screen Replacement, OLED Screen: 步骤 46 中的图像 1,1
    • The screws are very close to the screen. Applying too much pressure to the screws can stress or crack the screen. Be careful when unscrewing and screwing around the screen.
    • Remove the four 2mm #00 Philips head screws holding the screen in place from the eyepiece assembly.
    询问修复机器人
    添加评论
  47. HTC Vive OLED Screen Replacement: 步骤 47 中的图像 1,3 HTC Vive OLED Screen Replacement: 步骤 47 中的图像 2,3 HTC Vive OLED Screen Replacement: 步骤 47 中的图像 3,3
    • Use a plastic opening tool to gently pry around the seam between the eyepiece housing and the screen.
    • Gently pull the screen cover away from the eyepiece housing, threading the ribbon cable through the hole.
    询问修复机器人
    添加评论
  48. HTC Vive OLED Screen Replacement: 步骤 48 中的图像 1,2 HTC Vive OLED Screen Replacement: 步骤 48 中的图像 2,2
    • Remove the screen from the eyepiece housing by pulling the two pieces away from each other.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Caleb Watts
于09/25/17注册
2,439 声望
创作了11篇指南
团队
Cal Poly, Team S18-G1, Forte Fall 2017 Cal Poly, Team S18-G1, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G1
5 名成员
创作了22篇指南
3指南评论
This is a beautiful guide and I’m elated that I’ve found it. However, in order to use it, I need a place that I can get the screen since it has been flickering, color is off, and now it has a solid green vert line. Any direction? Thanks!
Jason - 回复 分享
Hi can you clean the vive OLED screen? if it has smudge mark on it… And what would you use
Al Shelley - 回复 分享
where do you buy a new screen from I’ve looked all over the net for it I can’t find one for my headset (htc vive cosmos elite)
Ian Miller - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 48
总计 5,129
