跳转到主内容
HP Sprocket 2-in-1 Outer Casing Replacement
Kevin Steward
Kevin Steward3 其他贡献者
最后更新于 May 16, 2023
9分钟
中等
This guide is necessary for all replacement guides for the HP Sprocket 2-in-1. All the images and directions use the iFixit Pro Tool Tech Kit. It is not necessary to use the kit but it is recommended. Be sure to prepare all tools and the device in a well-lit environment.
你所需要的
工具
查看更多...
  1. HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 1,2 HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 2 中的图像 1,2 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 2 中的图像 2,2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 3 中的图像 1,3 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 3 中的图像 2,3 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 3 中的图像 3,3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 4 中的图像 1,3 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 4 中的图像 2,3 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 4 中的图像 3,3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 5 中的图像 1,2 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 5 中的图像 2,2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 6 中的图像 1,3 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 6 中的图像 2,3 HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 6 中的图像 3,3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Outer Casing Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 423
