跳转到主内容
加入维修社区 - 创建账户
HP ProBook 455 G7 Battery Replacement
你所需要的
    1. HP ProBook 455 G7 Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      询问修复机器人
      添加评论
    2. HP ProBook 455 G7 Battery Replacement: 步骤 2 中的图像 1,3 HP ProBook 455 G7 Battery Replacement: 步骤 2 中的图像 2,3 HP ProBook 455 G7 Battery Replacement: 步骤 2 中的图像 3,3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      询问修复机器人
      添加评论
    1. HP ProBook 455 G7 Battery Replacement, Battery: 步骤 3 中的图像 1,3 HP ProBook 455 G7 Battery Replacement, Battery: 步骤 3 中的图像 2,3 HP ProBook 455 G7 Battery Replacement, Battery: 步骤 3 中的图像 3,3
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      询问修复机器人
      添加评论
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 1-6, Botvin Fall 2025 UMass Dartmouth, Team 1-6, Botvin Fall 2025 的会员
UMASSD-BOTVIN-F25S1G6
3 名成员
创作了36篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 31
总计 207
