跳转到主内容
HP Officejet Pro 8620 Printer Head Replacement
Scott
Scott2 其他贡献者
最后更新于 May 10, 2023
6分钟
简单
This guide will show how to replace the printer head for the printer.
  1. HP Officejet Pro 8620 Printer Head Replacement, Printer Head: 步骤 1 中的图像 1,1
    • Open the printer head cover door by pulling the cover door.
    • Power on the printer. This will move the print head to the left so you can access it.
    • Unplug the power cable from the back of the printer.
    • Do not power down the printer using the power button, as this will cause the printhead to move back to the right, making it incaccessible.
  2. HP Officejet Pro 8620 Printer Head Replacement: 步骤 2 中的图像 1,2 HP Officejet Pro 8620 Printer Head Replacement: 步骤 2 中的图像 2,2
    • Locate the printer head on the left side of the printer.
  3. HP Officejet Pro 8620 Printer Head Replacement: 步骤 3 中的图像 1,2 HP Officejet Pro 8620 Printer Head Replacement: 步骤 3 中的图像 2,2
    • Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
  4. HP Officejet Pro 8620 Printer Head Replacement: 步骤 4 中的图像 1,2 HP Officejet Pro 8620 Printer Head Replacement: 步骤 4 中的图像 2,2
    • Gently pull out the printer head.
    Ça veux dire que ça vaut pas la peine de démanche ça Pour la nettoyer
    louise - 回复
结论
13等其他人完成本指南。
Scott
于01/24/18注册
593 声望
创作了3篇指南
团队
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S19G2
1 名成员
创作了6篇指南
15条评论
Did not work for me on my HP 8620.
Sam Cauchi - 回复
Do you sell the replacement print head box for the HP Officejet pro 8620?
Do you post to England?
Thanks Pat Trotter
Pat Trotter - 回复
How about always paperjam and printhead just moving by 1 inch
Setiawan Ayooservice - 回复
Replacing easy.
BUT. Can it be repaired? Someone real experience with it?
PS. Of course only as no physical damage from outside and all 4 ink chambers (1) still sealed properly and (2) never have run empty
lbruederlin - 回复
Did not work for me. Followed the instruction and re installed the printhead. Same issue.
abenani2000 - 回复
DOES NOT WORK!!! I’ve tried ever remedy available. There is NO solution to this problem. If you do get it working, the error message will return shortly afterwards. I believe HP knew of this problem and deliberately chose not to find a remedy….thus class action. Frustrating. I’ve been told that it is designed for printers to fail now with a life expectancy of 3 years. And, I believe it. My printer is 3 years old. If you have this error message, you might as well throw it away. I’ve read other who had this issue purchased new print head, new cartridges, and nothing worked. HP is not the company they use to be. And, the new printers are not the same quality. Frustrating.
Cathy - 回复
Followed the steps to a”T" and did not correct the issue. The printer was working one day and the next the missing printer error appeared.
quinny1253 - 回复
What do we do now? HP seems not to as reliable as in the past. Can this printer be repaired as directed?
quinny1253 - 回复
The cartridge does not move to the left when I open the lid. It seems to be stuck. What can I do?
rinatkb - 回复
Worked on this for hours today. The printer was working yesterday, but came up with error saying printhead undetected, installed improperly, or failed. I uninstalled the ink cartridges, removed the printhead, uninstalled software, and was about to give up after trying every which way when I read to TRY ROCKING THE PRINTHEAD. It moves back and forth/up down a little bit ON THE CARRIAGE. Then I turned it on and off one more time before heading to best buy and tadah!!!!! It worked. Yay!!! Can’t find where I read that again, but I’ll never forget it!!
friendlygossip - 回复
Did not work for me after having followed the guidelines.
What do I do next to get the printer working. How do I tell if I need a new printer head?
Urgent direction is required from hp Officejet Pro 8620 manufactureres
Kofi Agbolegbe - 回复
These are the same procedures I found on the internet. I also tried them with no success. I weighed my options: 1) buy another HP8620, 2) buy another print head, 3) throw it out and buy another printer. Well, the HP8620 is no longer made, the few I could find were $450. Also, I had new ink in the printer and all new cartridges; about $120 invested. Option 2 seem like a good start, but brand-new U.S. made printer head were almost $200. I did find some for $40 made in China that were new. When it showed up, I installed it and had the same error. Option 3 is now in play! Off to the recycler it goes and maybe I can find someone who can use the ink. My conclusion is the circuitry in the printer itself is bad and not the actual print head.
Bruce991 - 回复
I have a HP 8610 and a 8620 both is a problem. I replace orig. ink new print head and it still report print heard problem. before that I went through all the process of cleaning the connections of the original electronic connections inside the print heads to no avail the printers do not work. clearing the memory do not help. I will go for Epson six ink tank printer next. I 've had six to seven HP printers its time to discard hp printers forever.
nathaniel aiken - 回复
do not buy hp printers!!!!!!
they do not work!!!!!
it's a scam!!!!!
JJ GG - 回复
printerhead does not move back to change cartridges
edgar lowe jr. - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 55
过去 30 天: 247
总计 25,820
