HP Officejet Pro 8620 Display Replacement
简介
转到步骤 1Follow this guide to remove a faulty display in your HP Officejet Pro 8620. If the touch-screen display is unresponsive, has image burn in, or stuck pixels you will need to replace the display.
Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
Open the display unit to expose the circuit board by separating the back and front panels.
Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
4等其他人完成本指南。
