跳转到主内容
HP LaserJet P1102w Left Side Panel Replacement
Jerome Etten
Jerome Etten3 其他贡献者
最后更新于 April 25, 2023
10 - 15 分钟
中等
These steps will show how to replace the left side panel from the printer. This prerequisite guide will be used for the power plug removal, motherboard removal, and half of the drive belt removal guides.
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: 步骤 1 中的图像 1,3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: 步骤 1 中的图像 2,3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: 步骤 1 中的图像 3,3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Left Side Panel Replacement: 步骤 2 中的图像 1,2 HP LaserJet P1102w Left Side Panel Replacement: 步骤 2 中的图像 2,2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Left Side Panel Replacement: 步骤 3 中的图像 1,2 HP LaserJet P1102w Left Side Panel Replacement: 步骤 3 中的图像 2,2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Left Side Panel Replacement: 步骤 4 中的图像 1,3 HP LaserJet P1102w Left Side Panel Replacement: 步骤 4 中的图像 2,3 HP LaserJet P1102w Left Side Panel Replacement: 步骤 4 中的图像 3,3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Left Side Panel Replacement: 步骤 5 中的图像 1,2 HP LaserJet P1102w Left Side Panel Replacement: 步骤 5 中的图像 2,2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Left Side Panel Replacement: 步骤 6 中的图像 1,3 HP LaserJet P1102w Left Side Panel Replacement: 步骤 6 中的图像 2,3 HP LaserJet P1102w Left Side Panel Replacement: 步骤 6 中的图像 3,3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Left Side Panel Replacement: 步骤 7 中的图像 1,2 HP LaserJet P1102w Left Side Panel Replacement: 步骤 7 中的图像 2,2
    • With all pry points free, remove the side panel.
结论
另外一个人完成了本指南。
Jerome Etten
于10/04/18注册
730 声望
创作了4篇指南
团队
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G4
4 名成员
创作了10篇指南
一条评论
How to replace the HP 2055 motherboard
Wale - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 62
总计 1,863
