跳转到主内容
HP Envy TouchSmart 15 Wireless Adapter Replacement
Robert Patterson
Robert Patterson3 其他贡献者
最后更新于 March 22, 2021
2 - 7 分钟
简单
You may need to replace the wireless adapter if your computer can't connect to any wireless network. Be sure that you do not break the antenna connector wires.
你所需要的
配件
工具
查看更多...
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: 步骤 3 中的图像 1,2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: 步骤 3 中的图像 2,2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 4 中的图像 3,3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: 步骤 5 中的图像 1,2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: 步骤 5 中的图像 2,2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 6 中的图像 1,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 6 中的图像 2,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 6 中的图像 3,3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    Hi
    Today I open my laptop to clean up a bit of dust. and by mistakenly I break black connector. not the thing is that the connector part from wireless card stuck inside black cable. but i can still use wifi without any problem. my question is " Is there any affect on my laptop if i leave it like this ?" and another question what is the functioning of that black cable ?
    hope I will get reply soon.please reply me on ronak.r.30588@gmail.com
    Thank you
    Ronak
    Ronnie M - 回复
结论
4等其他人完成本指南。
Robert Patterson
于09/04/15注册
1,457 声望
创作了5篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了10篇指南
1指南评论
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 3,249
