跳转到主内容
HP ElitePad 900 Volume Control Buttons Replacement
Kyle Marques
Kyle Marques7 其他贡献者
最后更新于 January 2, 2024
35 - 45 分钟
中等
动态照片拍摄
需要更多图片
Use this guide to replace the volume control buttons in your HP ElitePad tablet (Model 900). If the buttons on your tablet are not working properly or seem to be getting jammed consistently, they may need to be replaced. The volume buttons control the volume within the device and function by being pressed on from the sides of the tablet. The functionality of these buttons should be able to move back and forth in order to increase or decrease volume. Volume control buttons that are unable to be pressed all the way down or feel loose or have no response when being pressed down need to be replaced. Before using this guide ensure that nothing is in the way of the buttons preventing them from working. Prior to beginning the process of replacing the buttons it is important that the device is fully turned off and disconnected from any external power sources.
你所需要的
工具
查看更多...
  1. HP ElitePad 900 Volume Control Buttons Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Volume Control Buttons Replacement: 步骤 2 中的图像 1,2 HP ElitePad 900 Volume Control Buttons Replacement: 步骤 2 中的图像 2,2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Volume Control Buttons Replacement: 步骤 3 中的图像 1,2 HP ElitePad 900 Volume Control Buttons Replacement: 步骤 3 中的图像 2,2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: 步骤 4 中的图像 1,3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: 步骤 4 中的图像 2,3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: 步骤 4 中的图像 3,3
    • Using the Phillips screwdriver remove the two 2.4mm #000 screws that are securing the volume control buttons to the device.
    • Lift up the silver panel, removing it completely from the device
    • Push the buttons through the slot to remove them from the device
结论
Kyle Marques
于09/03/15注册
889 声望
创作了6篇指南
团队
USF Tampa, Team 12-4, Blackwell Fall 2015 USF Tampa, Team 12-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G4
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 708
