跳转到主内容
HP EliteBook x360 1030 G3 Battery Replacement
Pablo Arriola
Pablo Arriola5 其他贡献者
最后更新于 December 9, 2023
20分钟
中等
特色学生指南
If you are having power issues with this device, replacing the battery may be the solution. This guide will show you how to do so.
However, you should check through the troubleshooting page before proceeding, in case a simpler fix resolves the problem.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: 步骤 4 中的图像 1,2 HP EliteBook x360 1030 G3 Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
    Connector to the left may be stuck to the battery a little. Don’t worry just be careful.
    Leighton Doswell - 回复
  5. HP EliteBook x360 1030 G3 Battery Replacement: 步骤 5 中的图像 1,1
    • Gently lift the battery out of its place.
结论
10等其他人完成本指南。
Pablo Arriola
于04/22/19注册
528 声望
创作了3篇指南
团队
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G9
4 名成员
创作了16篇指南
5指南评论
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - 回复
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - 回复
Thank you. very useful.
mustapha ELABED - 回复
Very simple and precise with good warnings too
Roland Appiah - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 157
总计 13,405
