跳转到主内容
HP EliteBook 840 G9 Thermal Paste Replacement
Simeon Brankov
Simeon Brankov2 其他贡献者
最后更新于 February 14, 2025
10分钟
中等
社区贡献指南
Hello everyone, in this guide Ill be showing you how to open the laptop in order to change the thermal paste, as well as to possibly upgrade the RAM or the SSD inside.
你所需要的
配件
工具
查看更多...
  1. HP EliteBook 840 G9 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 1,3 HP EliteBook 840 G9 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 2,3 HP EliteBook 840 G9 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 3,3
    • Remove the 5 screws holding the back panel.
    • Use a prying tool to carefully release all the clips holding the panel in place.
  2. HP EliteBook 840 G9 Thermal Paste Replacement, Replacing the old thermal paste.: 步骤 2 中的图像 1,2 HP EliteBook 840 G9 Thermal Paste Replacement, Replacing the old thermal paste.: 步骤 2 中的图像 2,2
    • Unscrew the 4 screws holding the CPU heatsink and lift it up, gently.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
  3. HP EliteBook 840 G9 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): 步骤 3 中的图像 1,1
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want. Just carefully lift up the metal shields and replace them.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
结论
另外一个人完成了本指南。
Simeon Brankov
于11/08/20注册
7,180 声望
创作了54篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 47
总计 423
