跳转到主内容
HP EliteBook 840 G5 SSD Storage Replacement
你所需要的
  1. HP EliteBook 840 G5 SSD Storage Replacement, Back Cover: 步骤 1 中的图像 1,2 HP EliteBook 840 G5 SSD Storage Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 SSD Storage Replacement: 步骤 2 中的图像 1,3 HP EliteBook 840 G5 SSD Storage Replacement: 步骤 2 中的图像 2,3 HP EliteBook 840 G5 SSD Storage Replacement: 步骤 2 中的图像 3,3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 SSD Storage Replacement: 步骤 3 中的图像 1,1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 SSD Storage Replacement, SSD Storage: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the single 2mm screw that holds the SSD storage in place.
  5. HP EliteBook 840 G5 SSD Storage Replacement: 步骤 5 中的图像 1,2 HP EliteBook 840 G5 SSD Storage Replacement: 步骤 5 中的图像 2,2
    • The SSD storage will pop up.
    • Gently pull out the SSD from its slot.
结论
8等其他人完成本指南。
团队
Cal Poly, Team S25-G13, Maness Spring 2018 Cal Poly, Team S25-G13, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G13
4 名成员
创作了18篇指南
4指南评论
This guide was very useful.
I have only one to-add: take care of the little SSD screw (at step 4), don’t let it fall to the motherboard. For me it gave a bit of spark and smell.
Zoltán Szabó - 回复
Very useful guide indeed. To avoid issues issues similar to the above mentioned, it would be better to disconnect battery first.
Another question: can SSD drives with heat sink like WD SN750 Black be installed in this laptop?
Thanks
gdomenico - 回复
Before removing the SSD, should you not backup what's on that drive in order to reinstall it on the new SSD? Last question, can a replacement SSD be more than just 238 gb on this particular laptop?
mike._.feliciano - 回复
Should also unplug the battery. Any M2.2280 should be fine.
Daniel Bernardo -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 79
过去 30 天: 293
总计 30,193
