跳转到主内容
加入维修社区 - 创建账户
HMDX Jam Battery Replacement
你所需要的
    1. HMDX Jam Battery Replacement, Opening speaker: 步骤 1 中的图像 1,1
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      询问修复机器人
      添加评论
    2. HMDX Jam Battery Replacement, remove rubber cover: 步骤 2 中的图像 1,1
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      询问修复机器人
      添加评论
    3. HMDX Jam Battery Replacement, Remove screws: 步骤 3 中的图像 1,1
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      询问修复机器人
      添加评论
    4. HMDX Jam Battery Replacement, Exposing Battery: 步骤 4 中的图像 1,1
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      询问修复机器人
      添加评论
    5. HMDX Jam Battery Replacement, Removing Battery: 步骤 5 中的图像 1,1
      • Very gently remove the battery from the motherboard.
      添加评论
    6. HMDX Jam Battery Replacement, Remove battery attachments: 步骤 6 中的图像 1,2 HMDX Jam Battery Replacement, Remove battery attachments: 步骤 6 中的图像 2,2
      • Use a solder gun to remove the battery attachments from the motherboard.
      添加评论
结论
取消:我没有完成这个指南。
42等其他人完成本指南。
团队
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G1
4 名成员
创作了4篇指南
18指南评论
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - 回复 分享
Did you ever find out where to purchase a new battery for it?
DJ Ethics - 回复 分享
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - 回复 分享
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - 回复 分享
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 109
总计 98,749
