跳转到主内容
HMDX Jam Battery Replacement
你所需要的
  1. HMDX Jam Battery Replacement, Opening speaker: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
  2. HMDX Jam Battery Replacement, remove rubber cover: 步骤 2 中的图像 1,1
    • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
  3. HMDX Jam Battery Replacement, Remove screws: 步骤 3 中的图像 1,1
    • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
    • It would be wise to use a magnetic mat for the screws for safekeeping.
  4. HMDX Jam Battery Replacement, Exposing Battery: 步骤 4 中的图像 1,1
    • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
  5. HMDX Jam Battery Replacement, Removing Battery: 步骤 5 中的图像 1,1
    • Very gently remove the battery from the motherboard.
  6. HMDX Jam Battery Replacement, Remove battery attachments: 步骤 6 中的图像 1,2 HMDX Jam Battery Replacement, Remove battery attachments: 步骤 6 中的图像 2,2
    • Use a solder gun to remove the battery attachments from the motherboard.
    Disculpa. Que modelo es esa batería?
    Alberto Caamal - 回复
    Buenos días tengo un problema con una bocina jam se despegaron los cuatro cables y un conector
    Elías Gomez - 回复
    Bonjour, quel modèle de batterie dois acheter ?
    Prades - 回复
结论
41等其他人完成本指南。
团队
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G1
4 名成员
创作了2篇指南
18条评论
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - 回复
Did you ever find out where to purchase a new battery for it?
DJ Ethics -
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel -
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - 回复
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - 回复
have you even read the instructions?
simon -
Not sure if it is just mine or if this is actually how it charges. When I plug my HMDX Bluetooth earbuds, the light will turn red for a little bit then it turned off. Is it still charging or is something wrong with my earbuds?
Sean - 回复
No replies from the owner???wtf
siliconvalley952 -
Where do you buy the new battery
TIM BRADLEY - 回复
Should the red light come on as soon as I insert the usb cord?
wieslaws - 回复
Instructions above were helpful for my HMDX Jam model HX-P230A. To replace the battery, I bought a 3.7V 550 mAh battery on eBay for $7.50. (I believe the original battery was 500 mAh). See eBay listing at http://www.ebay.com/itm/251453907013. There's no manufacturer but the UPC is 737590401657 and the Model number is 053035. I'm not a great solderer so I did not unsolder the old battery. Instead I clipped the leads about half way. I then twisted the new battery wires onto the wires dangling from the circuit board. BTW - the wires are really small. After twisting, I soldered the twisted wires and then wrapped with electrical tape. So far, works like new again. Good luck with your battery replacement!
gvardakis1 - 回复
do you think the battery will work with a HX-P30D or is it only HX-P30A
rc car fun -
what about the HDMX 730 battery???
rsmc52 - 回复
"What replacement battery?" (in general)
Two Parameters:
1) Voltage:
3.7V should normally the default voltage (V) of this build-in Lithium batteries. I suppose you could choose any other Lithium Battery, with the same voltage. To the best of my knowledge.
2) Ampere:
The origin battery of HX-P230A has ~500mA (=0.5A). You could also take a higher A (ampere) to prolong use-time.
I personal chose Battery “NB-6L” (3.7V, 1600mAh). The physical dimension of this battery are nearly perfect for HX-P230A.
Labarnas_s331 - 回复
Qual o modelo da bateria, a minha vem com dois fios a mais preto e verde além dos fios da bateria
lopes.cleber - 回复
Best try to find replacement battery 1st!
B. Worden - 回复
My zero chill is only year old. No use at all. Red light comes on but unit will not turn on when I push the button. Is that battery? Thank you
Lorne Janes - 回复
Hey, how can I fix jam HX-P570?
Manice - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 147
总计 96,552
