跳转到主内容
加入维修社区 - 创建账户
HMD Fusion Screen Replacement
你所需要的
    1. HMD Fusion Screen Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone and completely power it down.
      询问修复机器人
      添加评论
    1. HMD Fusion Screen Replacement, Remove the SIM card tray: 步骤 2 中的图像 1,3 HMD Fusion Screen Replacement, Remove the SIM card tray: 步骤 2 中的图像 2,3 HMD Fusion Screen Replacement, Remove the SIM card tray: 步骤 2 中的图像 3,3
      • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
      • Remove the SIM card tray.
      询问修复机器人
      添加评论
    1. HMD Fusion Screen Replacement, Remove the back cover screws: 步骤 3 中的图像 1,3 HMD Fusion Screen Replacement, Remove the back cover screws: 步骤 3 中的图像 2,3 HMD Fusion Screen Replacement, Remove the back cover screws: 步骤 3 中的图像 3,3
      • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
      • Use your fingernails, or angled tweezers, to remove any stuck screws.
      • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
      添加评论
    2. HMD Fusion Screen Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      Magnetic Project Mat
      $19.95
      • During the next four steps, the remaining back cover screws might fall out unexpectedly.
      • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
      询问修复机器人
      添加评论
    3. HMD Fusion Screen Replacement, Unclip the back cover: 步骤 5 中的图像 1,2 HMD Fusion Screen Replacement, Unclip the back cover: 步骤 5 中的图像 2,2
      • Flip your phone over so the screen is facing up.
      • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
      询问修复机器人
      添加评论
    4. HMD Fusion Screen Replacement: 步骤 6 中的图像 1,3 HMD Fusion Screen Replacement: 步骤 6 中的图像 2,3 HMD Fusion Screen Replacement: 步骤 6 中的图像 3,3
      • Slide the opening pick along the left edge to begin unclipping the back cover.
      询问修复机器人
      添加评论
    5. HMD Fusion Screen Replacement: 步骤 7 中的图像 1,3 HMD Fusion Screen Replacement: 步骤 7 中的图像 2,3 HMD Fusion Screen Replacement: 步骤 7 中的图像 3,3
      • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
      • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
      • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
      询问修复机器人
      添加评论
    6. HMD Fusion Screen Replacement: 步骤 8 中的图像 1,3 HMD Fusion Screen Replacement: 步骤 8 中的图像 2,3 HMD Fusion Screen Replacement: 步骤 8 中的图像 3,3
      • Carefully flip your phone over so the back cover is facing up.
      • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
      • Be very careful not to strain the back cover's delicate cable.
      • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
      询问修复机器人
      添加评论
    7. HMD Fusion Screen Replacement, Disconnect the battery: 步骤 9 中的图像 1,3 HMD Fusion Screen Replacement, Disconnect the battery: 步骤 9 中的图像 2,3 HMD Fusion Screen Replacement, Disconnect the battery: 步骤 9 中的图像 3,3
      询问修复机器人
      添加评论
    8. HMD Fusion Screen Replacement, Disconnect the power button: 步骤 10 中的图像 1,3 HMD Fusion Screen Replacement, Disconnect the power button: 步骤 10 中的图像 2,3 HMD Fusion Screen Replacement, Disconnect the power button: 步骤 10 中的图像 3,3
      • Use a spudger to pry up and disconnect the power button press connector.
      • Remove the back cover.
      添加评论
    1. HMD Fusion Screen Replacement, Screen: 步骤 11 中的图像 1,3 HMD Fusion Screen Replacement, Screen: 步骤 11 中的图像 2,3 HMD Fusion Screen Replacement, Screen: 步骤 11 中的图像 3,3
      • For the next step, you'll need to hold the graphite sheet out of the way of the display connector along the bottom of the motherboard.
      • Alternatively, you can use tape with light adhesive (such as painter's tape) to keep the graphite sheet out of the way.
      询问修复机器人
      添加评论
    2. HMD Fusion Screen Replacement, Disconnect the display: 步骤 12 中的图像 1,2 HMD Fusion Screen Replacement, Disconnect the display: 步骤 12 中的图像 2,2
      • Use a spudger to pry up and disconnect the display press connector.
      • Pry under the right edge of the connector, as there are delicate surface‑mounted components to the left of it.
      询问修复机器人
      添加评论
    3. HMD Fusion Screen Replacement, Separate the front camera: 步骤 13 中的图像 1,2 HMD Fusion Screen Replacement, Separate the front camera: 步骤 13 中的图像 2,2
      • Use the tip of a spudger to pry up the front camera from the frame and separate its adhesive.
      询问修复机器人
      添加评论
    4. HMD Fusion Screen Replacement, Remove the screen screws: 步骤 14 中的图像 1,2 HMD Fusion Screen Replacement, Remove the screen screws: 步骤 14 中的图像 2,2
      • Use a T3 Torx screwdriver to remove the seven 3.3 mm‑long screws securing the screen:
      • Five screws on the motherboard
      • Two screws on the loudspeaker
      • One of the screws on the loudspeaker may be covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
      询问修复机器人
      添加评论
    5. HMD Fusion Screen Replacement, Remove the screen: 步骤 15 中的图像 1,2 HMD Fusion Screen Replacement, Remove the screen: 步骤 15 中的图像 2,2
      • Lift the screen off the frame, making sure to thread the display cable through its slot.
      • Remove the screen.
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
250,037 声望
创作了1,203篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了61,630篇指南
7指南评论
Wo kann ich ein Ersatzdisplay bestellen? (Bin aus der Schweiz)
Ivan Haedo - 回复 分享
Will the parts ever be in stock in Europe? Pointless to buy a repairable phone when you can't buy the parts
Ejrj - 回复 分享
In teh description you remove the screen, but Ifix send a sreen with a frame fixed to it. no way this is gona fit.
L Verheul - 回复 分享
Yes, the new screen has a frame attached to it. Just remove every screw on it an detach the frame carefully. I guess the frame supports the screen for transportation.
Robert Reiter - 回复 分享
Hello, I am in Portugal, can I buy the screen on this website?
Sand.barack - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 128
过去 30 天: 504
总计 9,120
