跳转到主内容
加入维修社区 - 创建账户
Google Pixel 9 Pro Rear Cover Replacement
你所需要的
  1. Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: 步骤 2 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: 步骤 2 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: 步骤 2 中的图像 3,3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: 步骤 3 中的图像 1,2 Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: 步骤 3 中的图像 2,2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 3,3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro Rear Cover Replacement: 步骤 6 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement: 步骤 6 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement: 步骤 6 中的图像 3,3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro Rear Cover Replacement: 步骤 7 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement: 步骤 7 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement: 步骤 7 中的图像 3,3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: 步骤 8 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: 步骤 8 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: 步骤 8 中的图像 3,3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: 步骤 9 中的图像 1,2 Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. Google Pixel 9 Pro Rear Cover Replacement: 步骤 10 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement: 步骤 10 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement: 步骤 10 中的图像 3,3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: 步骤 11 中的图像 1,3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: 步骤 11 中的图像 2,3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: 步骤 11 中的图像 3,3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. Google Pixel 9 Pro Rear Cover Replacement, Remove the rear cover: 步骤 12 中的图像 1,1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
结论
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
160,329 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,996篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 59
过去 30 天: 285
总计 5,810
