跳转到主内容
How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro
你所需要的
  1. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the old rear cover adhesive: 步骤 1 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the old rear cover adhesive: 步骤 1 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the old rear cover adhesive: 步骤 1 中的图像 3,3
    • When removing the rear cover adhesive during this step, be very careful not to damage any of the fragile components near the perimeter of the frame.
    • Use a spudger to scrape up and remove all the old rear cover adhesive from the perimeter of the frame.
    • This will take some time as the adhesive can be tricky to remove. Work slowly and try to roll the adhesive onto itself.
    • Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
    • In order for the new adhesive to form a good bond, the frame needs to be completely clean of all adhesive and its residue.
  2. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 2 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 2 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 2 中的图像 3,3
    • If you're installing a new rear cover, skip this step.
    • Repeat the previous step to remove all the rear cover adhesive and its residue from the underside of the rear cover.
  3. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Apply the new rear cover adhesive: 步骤 3 中的图像 1,1
    • Remove the larger clear liner from the rear cover adhesive.
  4. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 4 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 4 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 4 中的图像 3,3
    • Be very careful during this step! Once the adhesive sticks to the frame, you won't be able to reposition it. If the adhesive gets applied incorrectly, you'll have to start over with a new one.
    • Carefully place the adhesive onto the frame so the large cutout goes over the cameras. Use the frame's lip to help position the sheet.
  5. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Secure the rear cover adhesive: 步骤 5 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Secure the rear cover adhesive: 步骤 5 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Secure the rear cover adhesive: 步骤 5 中的图像 3,3
    • Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
  6. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the first liner: 步骤 6 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the first liner: 步骤 6 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the first liner: 步骤 6 中的图像 3,3
    • Grip the top right corner of the large blue liner with tweezers or your fingers and remove the liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  7. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 7 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 7 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 7 中的图像 3,3
  8. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Prop up the rear cover: 步骤 8 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Prop up the rear cover: 步骤 8 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Prop up the rear cover: 步骤 8 中的图像 3,3
    • Remove any liners from the underside of the rear cover, near the camera cutout area.
    • Apply a suction handle to the back of the rear cover, as close to the center of the right edge as possible.
    • Prop up the rear cover just to the right of your phone.
  9. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Reconnect the rear cover: 步骤 9 中的图像 1,2 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Reconnect the rear cover: 步骤 9 中的图像 2,2
    • Reconnect the rear cover press connector to the logic board.
    • Lay the wireless charging assembly into place.
  10. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 10 中的图像 1,2 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 10 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to install the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to hold it in place.
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
  11. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the remaining liners: 步骤 11 中的图像 1,2 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Remove the remaining liners: 步骤 11 中的图像 2,2
    • Grip the left pull tab on the bottom edge of the frame and remove the blue liner from the left edge of your phone.
  12. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 12 中的图像 1,2 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 12 中的图像 2,2
    • With one hand, use the suction handle to hold the rear cover over your phone. Remember that the rear cover is attached to the phone with a delicate cable.
    • With your free hand, use tweezers or your fingers to remove the remaining blue liner and expose the rear cover adhesive.
  13. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Attach the rear cover: 步骤 13 中的图像 1,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Attach the rear cover: 步骤 13 中的图像 2,3 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro, Attach the rear cover: 步骤 13 中的图像 3,3
    • Lay the rear cover onto the frame and firmly press it into place.
  14. How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 14 中的图像 1,2 How to Apply New Rear Cover Adhesive in Your Google Pixel 9 Pro: 步骤 14 中的图像 2,2
    • Firmly squeeze around the entire perimeter of the rear cover to secure it with the adhesive.
    • When powering on your Pixel for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen (fingers, plastic liners, screen protectors, cases).
结论
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
104,240 声望
创作了740篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,768篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 60
总计 681
