跳转到主内容
加入维修社区 - 创建账户
Google Pixel 7a Wireless Charging Assembly Replacement
你所需要的
  1. Google Pixel 7a Wireless Charging Assembly Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 2,2
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
    添加评论
  2. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the adhesive: 步骤 2 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
    • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
    添加评论
  3. Google Pixel 7a Wireless Charging Assembly Replacement, Secure an Anti-Clamp: 步骤 3 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Secure an Anti-Clamp: 步骤 3 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Secure an Anti-Clamp: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
    • Squeeze the cups together to create suction.
    询问修复机器人
    添加评论
  4. Google Pixel 7a Wireless Charging Assembly Replacement, Use the Anti-Clamp to create a gap: 步骤 4 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Use the Anti-Clamp to create a gap: 步骤 4 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Use the Anti-Clamp to create a gap: 步骤 4 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    询问修复机器人
    添加评论
  5. Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using the Anti-Clamp: 步骤 5 中的图像 1,1
    • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
    • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
    • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
    • Insert an opening pick into the gap between the rear cover and the frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
    • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
    询问修复机器人
    添加评论
  6. Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using a suction handle: 步骤 6 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using a suction handle: 步骤 6 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using a suction handle: 步骤 6 中的图像 3,3
    • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
    • Apply a suction handle to the center of the bottom edge of the rear cover.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
    询问修复机器人
    添加评论
  7. Google Pixel 7a Wireless Charging Assembly Replacement, Adhesive information: 步骤 7 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Adhesive information: 步骤 7 中的图像 2,2
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
    添加评论
  8. Google Pixel 7a Wireless Charging Assembly Replacement, Angle the opening pick: 步骤 8 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Angle the opening pick: 步骤 8 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Angle the opening pick: 步骤 8 中的图像 3,3
    • Angle the opening pick upward so the tip faces away from the frame.
    • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
    • Slide your pick to the bottom left corner of the rear cover.
    • Leave this pick in place to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  9. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the bottom edge adhesive: 步骤 9 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the bottom edge adhesive: 步骤 9 中的图像 2,2
    • Insert a second opening pick in the bottom left corner.
    • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
    询问修复机器人
    添加评论
  10. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the right edge adhesive: 步骤 10 中的图像 1,1
    • Apply a heated iOpener to the right edge of the rear cover for two minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
    询问修复机器人
    添加评论
  11. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the right edge adhesive: 步骤 11 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the right edge adhesive: 步骤 11 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the right edge adhesive: 步骤 11 中的图像 3,3
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a third opening pick in the bottom right corner of the rear cover.
    • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
    询问修复机器人
    添加评论
  12. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the left edge adhesive: 步骤 12 中的图像 1,1
    • Apply a heated iOpener to the left edge of the rear cover for two minutes.
    询问修复机器人
    添加评论
  13. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the left edge adhesive: 步骤 13 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the left edge adhesive: 步骤 13 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the left edge adhesive: 步骤 13 中的图像 3,3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid damaging the wireless charging coil and rear cover foam pad.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom left corner of the rear cover.
    • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
    询问修复机器人
    添加评论
  14. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the top edge adhesive: 步骤 14 中的图像 1,1
    • Apply a heated iOpener to the top edge of the rear cover for two minutes.
    询问修复机器人
    添加评论
  15. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the antenna bracket adhesive: 步骤 15 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the antenna bracket adhesive: 步骤 15 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the antenna bracket adhesive: 步骤 15 中的图像 3,3
    • There's a thick strip of adhesive along the antenna housing.
    • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
    • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
    • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
    添加评论
  16. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the remaining top edge adhesive: 步骤 16 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the remaining top edge adhesive: 步骤 16 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the remaining top edge adhesive: 步骤 16 中的图像 3,3
    • Pull your opening pick out to a depth of 3 mm.
    • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
    • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
    询问修复机器人
    添加评论
  17. Google Pixel 7a Wireless Charging Assembly Replacement, Rotate your top edge opening picks: 步骤 17 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Rotate your top edge opening picks: 步骤 17 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Rotate your top edge opening picks: 步骤 17 中的图像 3,3
    • Remember to angle your picks upward and away from the frame during this step.
    • Roll the top edge pick so its flat edge is under the rear cover.
    • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
    询问修复机器人
    添加评论
  18. Google Pixel 7a Wireless Charging Assembly Replacement, Pry up the camera bar: 步骤 18 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Pry up the camera bar: 步骤 18 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Pry up the camera bar: 步骤 18 中的图像 3,3
    • There's a long strip of adhesive securing the rear cover below the camera bar.
    • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
    • Pry back and forth until the camera bar loosens.
    • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
    询问修复机器人
    添加评论
  19. Google Pixel 7a Wireless Charging Assembly Replacement, Finish separating the adhesive: 步骤 19 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Finish separating the adhesive: 步骤 19 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Finish separating the adhesive: 步骤 19 中的图像 3,3
    • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
    询问修复机器人
    添加评论
  20. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the rear cover: 步骤 20 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Remove the rear cover: 步骤 20 中的图像 2,2
    • Remove the rear cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your rear cover.
    添加评论
  21. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the flash unit adhesive: 步骤 21 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Soften the flash unit adhesive: 步骤 21 中的图像 2,2
    • Apply a heated iOpener to the flash unit for one minute to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use a hair dryer or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
    询问修复机器人
    添加评论
  22. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the flash unit adhesive: 步骤 22 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Separate the flash unit adhesive: 步骤 22 中的图像 2,2
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • Slide your pick under the right edge of the flash to separate the adhesive securing it to the cover.
    添加评论
  23. Google Pixel 7a Wireless Charging Assembly Replacement, Clean the logic board cover: 步骤 23 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Clean the logic board cover: 步骤 23 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Clean the logic board cover: 步骤 23 中的图像 3,3
    在这个步骤中使用的工具:
    • If the copper tape lifted away with the flash, use tweezers or your fingers to remove the black foam residue from the logic board cover.
    添加评论
  24. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the old copper tape: 步骤 24 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Remove the old copper tape: 步骤 24 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Remove the old copper tape: 步骤 24 中的图像 3,3
    • Be careful not to damage the battery with your tool during this step.
    • Apply a heated iOpener to the underside of the flash for one minute.
    • Hold the neck of the flash cable steady and use tweezers to peel and remove the copper tape from the flash unit.
    • If the copper tape stayed on the logic board cover and you have a replacement, remove the old tape now.
    添加评论
  25. Google Pixel 7a Wireless Charging Assembly Replacement, Unfasten the logic board cover: 步骤 25 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Unfasten the logic board cover: 步骤 25 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • While the Pixel 7a uses Torx Plus screws, standard Torx drivers may still work. If your kit came with standard Torx bits, use the T2 bit to remove 1IP Torx Plus screws, and the T3 Torx bit to remove 3IP Torx Plus screws. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the thirteen 4.3 mm screws securing the logic board cover.
    • Use a 1IP Torx Plus driver to remove the 1.5 mm screw securing the right edge of the cover.
    添加评论
  26. Google Pixel 7a Wireless Charging Assembly Replacement, Unclip the logic board cover: 步骤 26 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Unclip the logic board cover: 步骤 26 中的图像 2,2
    • Insert an opening pick between the bottom right corner of the logic board cover and the frame.
    • Pry up to release the clip securing the cover.
    添加评论
  27. Google Pixel 7a Wireless Charging Assembly Replacement, Free the flash unit: 步骤 27 中的图像 1,3 Google Pixel 7a Wireless Charging Assembly Replacement, Free the flash unit: 步骤 27 中的图像 2,3 Google Pixel 7a Wireless Charging Assembly Replacement, Free the flash unit: 步骤 27 中的图像 3,3
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board into place.
    询问修复机器人
    添加评论
  28. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the wireless charging assembly: 步骤 28 中的图像 1,2 Google Pixel 7a Wireless Charging Assembly Replacement, Remove the wireless charging assembly: 步骤 28 中的图像 2,2
    • Remove the wireless charging assembly.
    添加评论
结论
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
取消:我没有完成这个指南。
2等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
103,988 声望
创作了476篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了17,855篇指南
1指南评论
Where can you buy a new wireless charging assembly?
Teagan Bliss - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 41
过去 30 天: 179
总计 5,330
