简介
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a cracked or broken Pixel 3a XL screen, or to get inside the phone and replace a different component.
The OLED display under the glass of the 3a XL screen is fragile—if you plan to re-use your screen after you remove it from your phone, take extra care and follow the directions of this guide closely.
你所需要的
视频概述
For reference, the backside of the screen is shown in this step.
Note the narrow clearance between the edge of the screen and the OLED panel under the glass. If you plan to re-use your screen, be sure to follow the instructions below closely.
Also note the two different seams between the body of the phone and the screen:
The screen seam: where the screen meets the rest of the phone. This is where the screen will separate, and where you should pry.
The midframe seam: where the midframe meets the body of the phone. This part is held down by screws. Do not pry at this seam.
If you aren't careful, the plastic opening tool can damage the fragile OLED display panel underneath the glass.
If you want to re-use your phone's screen, make sure you insert your pick at a downward angle, as shown in the second photo of this step.
This will ensure the opening pick slides under the OLED panel rather than between the glass and the panel, which will ruin the screen.
Pull up on the suction cup with a strong, steady force to create a gap between the screen and the phone.
Insert your opening pick into the gap.
Stop if you feel the tip of the pick hitting against something. The pick may be pressing against the edge of the OLED panel. Angle the pick downward and try again.
Carefully slide your opening pick around the upper-right-hand corner of the screen.
If you plan to reuse your screen, take special care in this step to either keep your pick deep in the phone under the OLED display (as shown in this step's photos), or only insert it 5 mm into the device to avoid coming into contact with the display under the glass.
Slide your opening pick along the bottom edge of the phone to separate the last of the adhesive holding the screen in place.
Don't try to remove the screen yet! It is still connected to the phone by a display cable.
在这个步骤中使用的工具:Tesa 61395 Tape$5.99
Use tweezers or an opening tool to remove all traces of adhesive from the phone frame. You can use high concentration isopropyl alcohol to help with the cleaning.
If you plan to re-use the screen, be sure to remove all adhesive residue from the screen. Be careful with metal tools to avoid scratching the screen.
Apply pre-cut adhesive or double-sided tape (such as Tesa tape) to re-attach the screen to the frame.
If your Pixel won't turn on after replacing the screen, there is a chance that the phone has silently turned on when the battery is re-connected. Hold the power button for a few seconds until the phone vibrates off. Afterwards, re-connect the screen, and try again.
Repair didn’t go as planned? Check out our Google Pixel 3a XL Answers community for troubleshooting help.
31等其他人完成本指南。
22条评论
I replaced the display and when it is turned on for the first time, everything works, but when it goes on standby when I switch it on again the touchscreen doesn't work anymore.
Rensan that is very weird! I would try resetting the phone, if you can? Sometimes that helps smooth out weird bugs with new Pixel displays.
I had the exact same issue, it was really weird. Turns out to be a hardware fault in the display, so I returned it and the new display works fine.
I'm having the same issue, gonna send the replacement screen in for a replacement. I got it from gadgetfix on eBay.
The screens got recalled for a period of time due to this exact issue. i only know about it because my screen had broken, and absolutely no parts supplier online or here locally in Los Angeles could even order the display assembly.
