跳转到主内容
加入维修社区 - 创建账户
Garmin Vivoactive Display Unit Replacement
你所需要的
    1. Garmin Vivoactive Display Unit Replacement, Wristband: 步骤 1 中的图像 1,1
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      询问修复机器人
      添加评论
    2. Garmin Vivoactive Display Unit Replacement: 步骤 2 中的图像 1,2 Garmin Vivoactive Display Unit Replacement: 步骤 2 中的图像 2,2
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      询问修复机器人
      添加评论
    1. Garmin Vivoactive Display Unit Replacement, Display Unit: 步骤 3 中的图像 1,1
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      询问修复机器人
      添加评论
    2. Garmin Vivoactive Display Unit Replacement: 步骤 4 中的图像 1,2 Garmin Vivoactive Display Unit Replacement: 步骤 4 中的图像 2,2
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      询问修复机器人
      添加评论
    3. Garmin Vivoactive Display Unit Replacement: 步骤 5 中的图像 1,1
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      询问修复机器人
      添加评论
    4. Garmin Vivoactive Display Unit Replacement: 步骤 6 中的图像 1,1
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      询问修复机器人
      添加评论
    5. Garmin Vivoactive Display Unit Replacement: 步骤 7 中的图像 1,1
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      询问修复机器人
      添加评论
    6. Garmin Vivoactive Display Unit Replacement: 步骤 8 中的图像 1,1
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
团队
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G21
4 名成员
创作了17篇指南
40指南评论
Does anyone knows where can I buy a vivoactive display?
dragomariano - 回复 分享
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - 回复 分享
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - 回复 分享
Any links found for replacement screen?
dskggray - 回复 分享
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 136
总计 105,329
