跳转到主内容
加入维修社区 - 创建账户
Game Boy Advance Motherboard Replacement
你所需要的
  1. Game Boy Advance Motherboard Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 1,2 Game Boy Advance Motherboard Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 2,2
    • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge installed, remove it.
    • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
    询问修复机器人
    添加评论
  2. Game Boy Advance Motherboard Replacement, Remove the battery cover: 步骤 2 中的图像 1,3 Game Boy Advance Motherboard Replacement, Remove the battery cover: 步骤 2 中的图像 2,3 Game Boy Advance Motherboard Replacement, Remove the battery cover: 步骤 2 中的图像 3,3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    询问修复机器人
    添加评论
  3. Game Boy Advance Motherboard Replacement, Remove the batteries: 步骤 3 中的图像 1,3 Game Boy Advance Motherboard Replacement, Remove the batteries: 步骤 3 中的图像 2,3 Game Boy Advance Motherboard Replacement, Remove the batteries: 步骤 3 中的图像 3,3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    询问修复机器人
    添加评论
  4. Game Boy Advance Motherboard Replacement, Remove the back shell screws: 步骤 4 中的图像 1,2 Game Boy Advance Motherboard Replacement, Remove the back shell screws: 步骤 4 中的图像 2,2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    询问修复机器人
    添加评论
  5. Game Boy Advance Motherboard Replacement, Remove the back shell: 步骤 5 中的图像 1,2 Game Boy Advance Motherboard Replacement, Remove the back shell: 步骤 5 中的图像 2,2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    询问修复机器人
    添加评论
  6. Game Boy Advance Motherboard Replacement, Remove the shoulder buttons: 步骤 6 中的图像 1,3 Game Boy Advance Motherboard Replacement, Remove the shoulder buttons: 步骤 6 中的图像 2,3 Game Boy Advance Motherboard Replacement, Remove the shoulder buttons: 步骤 6 中的图像 3,3
    • Lift the shoulder buttons (aka L and R buttons) straight up to remove them.
    • During reassembly:
    • Since your Game Boy is laying upside down, the L button will go on your right‑hand side, and the R button will go on your left‑hand side.
    • Slide the buttons into place, making sure the peg on the button goes into its circular cutout and the button itself is over the actual button mechanism.
    • The shoulder buttons will sit on the inside edge of the side bumpers.
    • Gently test the buttons to make sure they feel correct. If they don't, reposition them and make sure the metal arms aren't stuck in a weird position under the board.
    询问修复机器人
    添加评论
  7. Game Boy Advance Motherboard Replacement, Remove the side bumpers: 步骤 7 中的图像 1,3 Game Boy Advance Motherboard Replacement, Remove the side bumpers: 步骤 7 中的图像 2,3 Game Boy Advance Motherboard Replacement, Remove the side bumpers: 步骤 7 中的图像 3,3
    • Remove the side bumpers.
    询问修复机器人
    添加评论
  8. Game Boy Advance Motherboard Replacement, Remove the power switch cover: 步骤 8 中的图像 1,2 Game Boy Advance Motherboard Replacement, Remove the power switch cover: 步骤 8 中的图像 2,2
    • Remove the power switch cover.
    • During reassembly, make sure the switch cover is properly slotted around the arm on the switch mechanism.
    询问修复机器人
    添加评论
  9. Game Boy Advance Motherboard Replacement, Disconnect the screen cable: 步骤 9 中的图像 1,3 Game Boy Advance Motherboard Replacement, Disconnect the screen cable: 步骤 9 中的图像 2,3 Game Boy Advance Motherboard Replacement, Disconnect the screen cable: 步骤 9 中的图像 3,3
    • Use the point of a spudger to fully push up both locking tabs on either side of the screen cable connector.
    • You should feel the tab click into its unlocked position. Don't push too far, or the tab may slide completely out of the connector.
    询问修复机器人
    添加评论
  10. Game Boy Advance Motherboard Replacement: 步骤 10 中的图像 1,2 Game Boy Advance Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use tweezers to slide the cable straight out of its socket.
    • The cable should come out with little to no force. If you feel resistance, the tab may not be fully unlocked.
    询问修复机器人
    添加评论
  11. Game Boy Advance Motherboard Replacement, Remove the motherboard screws: 步骤 11 中的图像 1,2 Game Boy Advance Motherboard Replacement, Remove the motherboard screws: 步骤 11 中的图像 2,2
    • Use a JIS 1 screwdriver to remove the three 7 mm‑long screws securing the motherboard.
    询问修复机器人
    添加评论
  12. Game Boy Advance Motherboard Replacement, Remove the motherboard: 步骤 12 中的图像 1,3 Game Boy Advance Motherboard Replacement, Remove the motherboard: 步骤 12 中的图像 2,3 Game Boy Advance Motherboard Replacement, Remove the motherboard: 步骤 12 中的图像 3,3
    • Use your fingers to grip the cartridge reader and lift the motherboard straight up to remove it.
    • During reassembly, make sure the speaker gets correctly slotted into its circular cutout (including a small tab on the bottom) when lowering the motherboard into place.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
取消:我没有完成这个指南。
9等其他人完成本指南。
Spencer Day
于09/14/22注册
196,379 声望
创作了1,243篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 68
过去 30 天: 264
总计 23,007
