跳转到主内容
加入维修社区 - 创建账户
Fusion5 5.5 Gen II Microphone Replacement
你所需要的
    1. Fusion5 5.5 Gen II Microphone Replacement, Back Cover: 步骤 1 中的图像 1,2 Fusion5 5.5 Gen II Microphone Replacement, Back Cover: 步骤 1 中的图像 2,2
      • Hold the device with the screen facing away from you and the back of the device facing you.
      • Locate the groove at the bottom corner of the device.
      • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
      询问修复机器人
      添加评论
    1. Fusion5 5.5 Gen II Microphone Replacement, Microphone: 步骤 2 中的图像 1,2 Fusion5 5.5 Gen II Microphone Replacement, Microphone: 步骤 2 中的图像 2,2
      • The device is rotated upside down here but is not necessary.
      • Remove the six 3mm Phillips #00 screws securing the lower back frame to the device.
      • Slide the lower back frame away, revealing the microphone and the board that it is connected to.
      • When moving the lower back frame, be careful not to rip the wires for the bottom speaker that is attached to the lower back frame.
      询问修复机器人
      添加评论
    2. Fusion5 5.5 Gen II Microphone Replacement: 步骤 3 中的图像 1,1
      在这个步骤中使用的工具:
      • Using the tweezers, grasp the microphone and remove it from its socket on the device.
      • Straighten out the wires to make the next step easier.
      询问修复机器人
      添加评论
    3. Fusion5 5.5 Gen II Microphone Replacement: 步骤 4 中的图像 1,3 Fusion5 5.5 Gen II Microphone Replacement: 步骤 4 中的图像 2,3 Fusion5 5.5 Gen II Microphone Replacement: 步骤 4 中的图像 3,3
      • Rotate the device or have the bottom of the device facing you for easier access while soldering.
      • Using the tweezers and soldering iron, remove the red and black wires from the circuit board.
      • Make sure that the red wire is on the left connector and the black wire is on the right connector when you solder on the replacement component.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 32
总计 554
