跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Bottom Cover Disconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Framework Laptop 12 Bottom Cover Disconnect, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 Bottom Cover Disconnect, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 Bottom Cover Disconnect, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Bottom Cover Disconnect, Set your laptop down: 步骤 2 中的图像 1,1
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Bottom Cover Disconnect, Remove the Expansion Cards: 步骤 3 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Remove the Expansion Cards: 步骤 3 中的图像 2,2
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  4. Framework Laptop 12 Bottom Cover Disconnect: 步骤 4 中的图像 1,3 Framework Laptop 12 Bottom Cover Disconnect: 步骤 4 中的图像 2,3 Framework Laptop 12 Bottom Cover Disconnect: 步骤 4 中的图像 3,3
    • Grip the lip of an Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
    • Repeat this procedure to remove all remaining Expansion Cards.
  5. Framework Laptop 12 Bottom Cover Disconnect, Loosen the bottom screws: 步骤 5 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Loosen the bottom screws: 步骤 5 中的图像 2,2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  6. Framework Laptop 12 Bottom Cover Disconnect, Flip your laptop over: 步骤 6 中的图像 1,1
    • Flip your laptop face-up on your work surface.
  7. Framework Laptop 12 Bottom Cover Disconnect, Open your laptop: 步骤 7 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Open your laptop: 步骤 7 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  8. Framework Laptop 12 Bottom Cover Disconnect, Remove the Input Cover: 步骤 8 中的图像 1,3 Framework Laptop 12 Bottom Cover Disconnect, Remove the Input Cover: 步骤 8 中的图像 2,3 Framework Laptop 12 Bottom Cover Disconnect, Remove the Input Cover: 步骤 8 中的图像 3,3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • You may feel resistance from the magnets. If the cover feels like it's snagged, check that you've fully loosened the screws on the bottom of your laptop.
    • Remove the Input Cover.
  9. Framework Laptop 12 Bottom Cover Disconnect, Loosen the battery screws: 步骤 9 中的图像 1,1
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  10. Framework Laptop 12 Bottom Cover Disconnect, Disconnect the battery: 步骤 10 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Disconnect the battery: 步骤 10 中的图像 2,2
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  11. Framework Laptop 12 Bottom Cover Disconnect, Remove the battery: 步骤 11 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Remove the battery: 步骤 11 中的图像 2,2
    • Lift and remove the battery from the laptop.
  12. Framework Laptop 12 Bottom Cover Disconnect, Loosen the Audio Board screw: 步骤 12 中的图像 1,1
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
  13. Framework Laptop 12 Bottom Cover Disconnect, Remove the Audio Board: 步骤 13 中的图像 1,3 Framework Laptop 12 Bottom Cover Disconnect, Remove the Audio Board: 步骤 13 中的图像 2,3 Framework Laptop 12 Bottom Cover Disconnect, Remove the Audio Board: 步骤 13 中的图像 3,3
    • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
    • Remove the Audio Board.
  14. Framework Laptop 12 Bottom Cover Disconnect, Loosen the Power Button Board screw: 步骤 14 中的图像 1,1
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
  15. Framework Laptop 12 Bottom Cover Disconnect, Remove the Power Button Board: 步骤 15 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Remove the Power Button Board: 步骤 15 中的图像 2,2
    • Use your fingers to lift and remove the Power Button Board.
  16. Framework Laptop 12 Bottom Cover Disconnect, Loosen the Wi-Fi card screw: 步骤 16 中的图像 1,1
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi card bracket.
    • The Wi-Fi card will pop up slightly when you unfasten the bracket.
  17. Framework Laptop 12 Bottom Cover Disconnect, Remove the Wi-Fi card bracket: 步骤 17 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Remove the Wi-Fi card bracket: 步骤 17 中的图像 2,2
    • Grab the Wi-Fi card bracket with your fingers and slide it off the top of the Wi-Fi card.
    • Remove the bracket and store it in a safe location for reassembly.
  18. Framework Laptop 12 Bottom Cover Disconnect, Disconnect the antenna cables: 步骤 18 中的图像 1,3 Framework Laptop 12 Bottom Cover Disconnect, Disconnect the antenna cables: 步骤 18 中的图像 2,3 Framework Laptop 12 Bottom Cover Disconnect, Disconnect the antenna cables: 步骤 18 中的图像 3,3
    • The Wi-Fi card has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi card down with your finger.
    • Slide the flat edge of your Framework Screwdriver under the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  19. Framework Laptop 12 Bottom Cover Disconnect, Remove the Wi-Fi card: 步骤 19 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Remove the Wi-Fi card: 步骤 19 中的图像 2,2
    • Grab the Wi-Fi card by the edges and pull it out of its socket.
    • Remove the Wi-Fi card.
  20. Framework Laptop 12 Bottom Cover Disconnect, Disconnect the webcam cable: 步骤 20 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Disconnect the webcam cable: 步骤 20 中的图像 2,2
    • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
    • Lift straight up to disconnect the cable.
  21. Framework Laptop 12 Bottom Cover Disconnect, Disconnect the display cable: 步骤 21 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Disconnect the display cable: 步骤 21 中的图像 2,2
    • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
  22. Framework Laptop 12 Bottom Cover Disconnect, Loosen the Mainboard screws: 步骤 22 中的图像 1,1
    • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Mainboard.
    • These screws are also physically marked with an orange ring on the Mainboard.
  23. Framework Laptop 12 Bottom Cover Disconnect, Remove the Mainboard: 步骤 23 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Remove the Mainboard: 步骤 23 中的图像 2,2
    • Make sure you've removed all Expansion Cards. Installed cards will hold the Mainboard in place.
    • Use your fingers to grab the Mainboard by its edges.
    • Lift and remove the Mainboard.
  24. Framework Laptop 12 Bottom Cover Disconnect, Unthread the antenna cable: 步骤 24 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Unthread the antenna cable: 步骤 24 中的图像 2,2
    • Use your fingers to lift the black plastic loop securing the antenna cable, near the heat vents by the left hinge.
  25. Framework Laptop 12 Bottom Cover Disconnect: 步骤 25 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect: 步骤 25 中的图像 2,2
    • Use your fingers to lift and guide the antenna cable out of the frame channel.
  26. Framework Laptop 12 Bottom Cover Disconnect, Unthread the webcam cable: 步骤 26 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Unthread the webcam cable: 步骤 26 中的图像 2,2
    • Use your fingers to gently lift the webcam cable out of its plastic channel.
  27. Framework Laptop 12 Bottom Cover Disconnect, Disconnect the Top Cover: 步骤 27 中的图像 1,2 Framework Laptop 12 Bottom Cover Disconnect, Disconnect the Top Cover: 步骤 27 中的图像 2,2
    • Use your Framework Screwdriver to remove the six (three per hinge) 4.5 mm‑long T5 Torx screws securing the two hinges.
    • These screws are not captive. Store them in a safe location for reassembly.
  28. Framework Laptop 12 Bottom Cover Disconnect: 步骤 28 中的图像 1,3 Framework Laptop 12 Bottom Cover Disconnect: 步骤 28 中的图像 2,3 Framework Laptop 12 Bottom Cover Disconnect: 步骤 28 中的图像 3,3
    • Use your fingers to lift the hinges over the Bottom Cover lip.
    • Separate the Top Cover from the Bottom Cover.
终点
Arthur Shi
于01/03/18注册
324,650 声望
创作了802篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 69
