跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Bottom Cover Reconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Framework Laptop 12 Bottom Cover Reconnect, Reconnect the Top Cover: 步骤 1 中的图像 1,3 Framework Laptop 12 Bottom Cover Reconnect, Reconnect the Top Cover: 步骤 1 中的图像 2,3 Framework Laptop 12 Bottom Cover Reconnect, Reconnect the Top Cover: 步骤 1 中的图像 3,3
    • Use your fingers to lift the Top Cover hinges over the Bottom Cover lip.
    • Lay the hinges in place in the Bottom Cover.
    • Use the plastic alignment pins to align each hinge in place.
  2. Framework Laptop 12 Bottom Cover Reconnect: 步骤 2 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect: 步骤 2 中的图像 2,2
    • Use your Framework Screwdriver to install the six 4.5 mm‑long T5 Torx screws securing the two hinges.
  3. Framework Laptop 12 Bottom Cover Reconnect: 步骤 3 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect: 步骤 3 中的图像 2,2
    • Use your fingers to gently press the webcam cable into its plastic channel.
  4. Framework Laptop 12 Bottom Cover Reconnect: 步骤 4 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect: 步骤 4 中的图像 2,2
    • Use your fingers and your Framework Screwdriver to carefully press and guide the black antenna cable back into its channel.
    • Zoom in on the second image to see how the antenna cable sits in its channel.
  5. Framework Laptop 12 Bottom Cover Reconnect: 步骤 5 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect: 步骤 5 中的图像 2,2
    • Press the black loop over the antenna cable and onto the Bottom Cover. If it doesn't stick, use a bit of thin double-sided tape to hold it down.
  6. Framework Laptop 12 Bottom Cover Reconnect, Install the Mainboard: 步骤 6 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect, Install the Mainboard: 步骤 6 中的图像 2,2
    • Carefully lay the Mainboard in the laptop.
    • Use the two alignment pins to help align the Mainboard to the laptop.
    • Be careful not to trap the webcam, display, and antenna cables under the Mainboard as you set it in place.
  7. Framework Laptop 12 Bottom Cover Reconnect: 步骤 7 中的图像 1,1
    • Use your Framework Screwdriver to tighten the five captive T5 Torx screws to secure the Mainboard.
  8. Framework Laptop 12 Bottom Cover Reconnect: 步骤 8 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect: 步骤 8 中的图像 2,2
    • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
    • Align and press the display cable straight down onto its connector.
  9. Framework Laptop 12 Bottom Cover Reconnect: 步骤 9 中的图像 1,2 Framework Laptop 12 Bottom Cover Reconnect: 步骤 9 中的图像 2,2
    • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
    • Align and press the webcam cable straight down onto its connector.
结论
Arthur Shi
于01/03/18注册
325,466 声望
创作了810篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 49
